1990 Subaru Liberty - How do I get the ignition barrel out?
Posted: Sat Jan 22, 2011 1:33 pm
by Daydream
Hi all,
Just had my car stolen and the b******s shoved a pair of scissors or something into the ignition barrel so now the key doesn't work in it. Rang a locksmith, who are asking ridiculous prices to come out and fix it ($400), but found one who will do it cheap if I can get the barrel out of the steering column and bring it into the shop.
Only problem is, I have no idea how to do this.....any help?
Also, sorry if there is an obvious place within this forum that can tell me how to do this, but when I searched for "ignition" I got over 500 thread results....
Posted: Sat Jan 22, 2011 1:44 pm
by Daydream
Sorry, I realise now that this is in the wrong section......derrr.
Can't seem to delete or move my thread.
Posted: Sat Jan 22, 2011 2:02 pm
by littlewhiteute
Can't say I've had a Subaru ignition barrel out, but most barrels have to be in the accessory position first, then depressing a locking device through a tiny hole in the column housing releases the barrel.
Posted: Tue Jan 25, 2011 7:57 pm
by richard the fish
Did mine after snapping the key easy. Use an angle grinder fast too
Posted: Tue Jan 25, 2011 8:38 pm
by Gannon
Remove both the top and bottom trim pieces around the steering column.
You should then be able to use a screwdriver (but an impact driver will be better because they can be quite tight) to undo 2 screws that hold the barrel to the steering column.
Posted: Wed Jan 26, 2011 4:18 am
by RSR 555
Suparoo wrote:Remove both the top and bottom trim pieces around the steering column.
Pretty much follow what Gannon has said but the screws normally are security snap bolts. This means when the manufacture installs them they screw in with a thread then when they are tight the heads snap off leaving a blind head. I've found using a centre punch (on an angle) and a hammer and hitting the head in a unscrewing motion, will loosen them to the point where you can unscrew them with your fingers.. then buy yourself the complete unit from a wreckers and when you go to install, you can either buy the factory bolts or just cut a slot with a hacksaw and install with a flat blade screwdriver
Posted: Wed Jan 26, 2011 10:41 am
by Captain Obvious
easiest thing and cheapest thing to will be find a wreck that has the keys pull out all the door lock and ing barrell and put in your car. or just get a ing barrel and have 2 keys one for the door one to start the car!!
bryan
