immobilizer problems
Posted: Fri Aug 23, 2013 10:02 am
by tans rex
Hi all
My wifes 02 wrx is having a few immobilizer dramas. Sometimes the key light on the dash wont go out & the engine starts then stops straight away. The other night will driving to her sisters the key light flashed while she was driving & when she turned the car off it would not start again. I had to disconnect the battery for 15mins then everything was ok. Is the immobilizer having a meltdown? Just a note too I have bypassed the stupid keypad for the brandt system too. I want the brandt removed but I dont think its the cause of the problem on this occasion. Any thoughts would be appriciated.
Posted: Fri Aug 23, 2013 12:59 pm
by Gannon
I had it before where one of the plugs was loose and not making a good connection at the immobiliser. How did you remove the keypad and still allow the brandt to work?
Posted: Fri Aug 23, 2013 9:21 pm
by littlewhiteute
More than likely the Brandt is the cause of your problem.
My 2002 WRX EVO 5 has an issue of no crank intermittently hot, I know if I knock the dash near the glovebox, it will crank and run normally.
Google Brandt, there heaps on the net.
