Black fusible link for L series and tyres
Hi Gang
Im chasing a black fusible link for a l series.
Also im looking for some secondhand 205/ 60 to 70 /15 tyres for my outback.
Cheers Pete
Cheers Pete
Use The Fork Luke
You can buy plug in plastic case fusible links from an auto electricians, they look like this
But if you are replacing a black fusible link, use a back plug in fusible link
Thanks
Thanks guys.
Thats helpful i appreciate the answers. I got the replacement motor in my vortex
(thanks Paul RSR ).Its running and tuned in but i can bbq a rack of beef on the wrong rated link i had to put in to finish the job lol.
Cheers Pete
Cheers Pete
Use The Fork Luke
I looked in the Narva catalogue at my local parts joint and they are universally colour coded accross all of the different types of fusible links including the old style copper wire ones. So red is red and black is black no matter what type of link it actually is.steptoe wrote:SCA also sell them, but have we established it is still colour for colour in the conversion of ratings ??
That seems odd, as the black fusible link supplies the ignition switch, the fuel pump relay, the ignition relay and ECU
Yeah regular fuses don't work! I've melted many trying to limp home one night on a 30A fuse. Can't remember which fuse it was though but the lights got very dim very quickly!coupe wrote:I went to the parts place and while im still trying to get a match i used a 25 amp fuse and a fuse bridge so i could run the car. the fuse blew as soon as i started it but the car still runs untill you turn it off , then you replace it to restart lol.
Yeah there must have been some sort of link in the fuse for this to work. I've driven on a completely fried black fusible link with lights very dim, warning lights glowing on the dash. When I stopped to check it out it stalled and I could start it like I had no battery connected.Gannon wrote:That seems odd, as the black fusible link supplies the ignition switch, the fuel pump relay, the ignition relay and ECU
It seems that I only have these fusible link events at night. Lucky me!
