Need a 5 speed for a L series or ? read this
seagull
Post by seagull » Fri Sep 01, 2006 12:58 am
soldddddddddddddddddddddddddddddddd
tim_81coupe
Post by tim_81coupe » Fri Sep 01, 2006 9:36 am
The question everyone asked about this box is not so much about the bolt pattern but the position of the starter motor. Is it located directly on top of the box or over to the passenger side like all the later motors?
All the EA71's I have seen have the starter located up top.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
seagull
Post by seagull » Fri Sep 01, 2006 10:30 am
passengers side like I tryed to tell every one , for all I know the ea81 would bolt up .some one need to give it a go .
SuBaRiNo
Post by SuBaRiNo » Fri Sep 01, 2006 8:25 pm
im interested... do u know the ratio??? also what does this "vacuum rear out put lock" mean... is this a vacume switch for turning 4wd on and off??
Dave
subanator
Post by subanator » Fri Sep 01, 2006 10:43 pm
Doesnt sound like a Dual - Range box?
seagull
Post by seagull » Fri Sep 01, 2006 11:43 pm
this is a single range box , with a Vacuum rear tail shaft lock > you can run front wheel drive on the road & rear wheel drive on or off the road .Dave a quick look its a 3.7 ratio
SuBaRiNo
Post by SuBaRiNo » Fri Sep 01, 2006 11:52 pm
ok thanks mate... really need dual range... thans anyways.
Dave
seagull
Post by seagull » Sat Sep 02, 2006 10:44 am
Thats cool
seagull
Post by seagull » Sun Sep 03, 2006 11:18 pm
Dave , I have a Duel range L series gear box 3.9 ratio low K unit .I would like $380.00 for it .
Seagull
SuBaRiNo
Post by SuBaRiNo » Sun Sep 03, 2006 11:33 pm
nar im fine... don't need a new box was just interested in the vacume part on the other box. Thanks anyways.
Dave
seagull
Post by seagull » Sun Sep 03, 2006 11:40 pm
No problems .The box is there is any one is in Need
The vacuum part is interesting , I had a llok at it today while having a farthers day beer .
after three beers I nealy pulled it apart !
SuBaRiNo
Post by SuBaRiNo » Sun Sep 03, 2006 11:56 pm
ahaha could be interesting to see what else could be made out of it.
Dave
seagull
Post by seagull » Mon Sep 04, 2006 12:08 am
yes I wish I could use it for my Turbo vw bug gear box .
Return to “Western Australia”
