ive got a issue
90brumby
ive got a issue
Post by 90brumby » Tue Jun 03, 2008 10:31 pm
i need a bash plate b4 i can do any 4x4in any1 who has seen my car will deffently agree with me on that n i need to swap the diff over but i got a 3.9 now so basicly im askin where other people got the bash plate made or the material from n wat its mounted to cause the orignal mountin seams fairly weak
cheers Tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by Subafury » Tue Jun 03, 2008 11:01 pm
i know of a 3.9 welded diff that should be coming out of justins car very soon.
as for the bash plate id say get it done from 3-5mm thick steel. mine is 1.6 and def too thin for big hits but does the job for the smaller bumps. it mounts to some tophat steel i tek'd to the metat under the stoneguard- but yours may be different being MY
plucky
Post by plucky » Tue Jun 03, 2008 11:03 pm
Get 2 Std bash plates and follow the instructions in the tech section of the QLD club site (on here). I have done mine this way and it works a treat. The Std one will fit with a 2" lift if you just elongate the holes with a file and bend it slightly along the back edge - you can bend it ih a vice. The bash plate bolts to the crossmember which is quite strong. Better to throw away a bash plate than something more serious!
rtcb65
Post by rtcb65 » Tue Jun 03, 2008 11:33 pm
plucky wrote:Get 2 Std bash plates and follow the instructions in the tech section of the QLD club site (on here). I have done mine this way and it works a treat. The Std one will fit with a 2" lift if you just elongate the holes with a file and bend it slightly along the back edge - you can bend it ih a vice. The bash plate bolts to the crossmember which is quite strong. Better to throw away a bash plate than something more serious!
Any chance you could post a link to the thread/ post about the bash plate.
Thanks
rtcb65
Redneck Rick.
Post by AndrewT » Wed Jun 04, 2008 12:07 am
I'd advise to go for some ally checkerplate. It's tough stuff and light weight.
I would mount it from the bullbar right through to under the gearbox mounts.
For your car perhaps go extreme like the one in BrumbyRunner's thread - it's quite large :)
Post by D3V1L » Fri Jun 27, 2008 3:11 pm
i beleive u need to see pics of tristans brumby before saying that
i think that there is a little more needed then 2 plates joined together:P
MASSIVE surface area is needed
AFTER ALL...he has basically gotta cover an ENTIRE engine :D
dave
90brumby
Post by 90brumby » Sat Jun 28, 2008 10:50 pm
i now have a bash plate just gotta mount it to the car it will run from bull bar to mid crossmember its made of bout 3mm plate steel n it runs from the bull bar brackets either side it could b a bit excessive but ahwell bigger is better
Post by AndrewT » Sun Jun 29, 2008 8:03 pm
steel....must weigh heaps??
yarney
Post by yarney » Sun Jun 29, 2008 9:12 pm
rtcb65 wrote:Any chance you could post a link to the thread/ post about the bash plate.
Thanks
Hi rtcb65 here is the link http://www.subaclub.com go to tech talk
Jan
Return to “Western Australia”
