Brumby/EJ25 conversion wiring harness
Corax
Post by Corax » Tue Apr 07, 2009 9:27 pm
Hey WA Suba dudes,
Does anybody out there know someone who is full bottle on wiring harnesses in WA? I want to put a 2002 impreza EJ25 into my brumby but basically know bugger all about harnesses. My main problems being I think the harness I got with the moter is incomplete and I am missing the various sensors (airflow etc). Thanks for any help you can give.
Corax.
Post by AndrewT » Tue Apr 07, 2009 9:37 pm
Hit up Subarino with some questions, he's the only one I know in WA who is full bottle on the subject!
vidler
Post by vidler » Wed Apr 08, 2009 11:33 pm
cutting chassis rails?
09 Forester XT Touring Wagon
Outback bloke
Post by Outback bloke » Thu Apr 09, 2009 4:20 am
You don't need to cut rails if you are putting in a twin cam motor.
Post by AlpineRaven » Thu Apr 09, 2009 7:50 am
Outback bloke wrote:You don't need to cut rails if you are putting in a twin cam motor.
Isn't it a SOHC engine? I thought the impreza were SOHC not DOHC?
Post by AndrewT » Thu Apr 09, 2009 12:22 pm
lol.....the old confusing cams thing :)
In this case I think Outback Bloke is referring to the SOHC engine when he says TwinCam.
SOHC means 1 cam on each head. But it's a Subaru engine, so 2 heads, which means 2 cams.....so some people call them a Twincam.
If it's a DOHC then it has 2 cams on each head (like a twincam in a Corolla), but there are 2 heads, so 4 cams......some people call these a Quad Cam.
It's only the Quadcam engines that are too wide and need the chassis rails cut in a Brumby.
I think the Impreza EJ25's of that era were the SOHC ones so should be fine to fit in this case.
FROG
Post by FROG » Thu Apr 09, 2009 1:37 pm
ej201 sohc na
ej202 sohc na
ej204 dohc na
ej205 dohc turbo
ej207 dohc hi po turbo
ej208 dohc twin turbo
ej251 sohc na 2500
ej252 sohc na 2500
ej253 sohc na 2500
ej255 dohc turbo 2500
ej257 dohc hi po turbo 2500
may help someone :D
Outback bloke
Post by Outback bloke » Thu Apr 09, 2009 2:31 pm
Yes that is what I mean. I base it on the stickers on the RS turbo doors seeing as though they were the first with that motor. They call it a quad cam.
Corax
Post by Corax » Thu Apr 09, 2009 6:46 pm
Hi guys,
Yeah the moter is SOHC na type and I have measured it and in theory it should fit without chopping the rails. One of the main reasons I went for this moter actually cause I have heard that once you start chopping stuff it becomes a real drama to get it licenced. Cheers for the info AndrewT, will try to get in contact with subarino and sort my harness issues!
Corax.
SuBaRiNo
Post by SuBaRiNo » Tue Apr 14, 2009 9:16 pm
If you have tryed to get a hold of me you have failed so far. I have cut down probably over 10 EJ hanesses... 2 of them being Ej25 so i should be able to offer some assistance.
Best bet is to add me to MSN or email me ([email protected]).... im not on this site very often.
Dave
Post by Subafury » Tue Apr 14, 2009 10:40 pm
FROG wrote:ej201 sohc na
ej202 sohc na
ej204 dohc na
ej205 dohc turbo
ej251 sohc na 2500
ej252 sohc na 2500
ej253 sohc na 2500
may help someone :D
helped me. now if you could match them with their common subaru models :)
Matatak
Post by Matatak » Tue Apr 14, 2009 10:42 pm
ej202 sohc na
ej204 dohc na
ej205 dohc turbo
ej251 sohc na 2500
ej252 sohc na 2500
ej253 sohc na 2500
may help someone :D
Where does the DOHC NA 2.5 come into it then ?
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by AndrewT » Tue Apr 14, 2009 11:57 pm
I think that's known as the EJ25D
http://en.wikipedia.org/wiki/Subaru_EJ_engine#EJ25
Return to “Western Australia”
