Parts parts parts
chriSTIan
Parts parts parts
Post by chriSTIan » Wed Aug 19, 2009 8:36 pm
Hi all
Having a look around the shed and its time to clear out some stuff that i will never use.
Here is a list off the top of my head of whats up for grabs:
1 sti spoiler lip to fit gen1 Series 2 rs front bumper,f/glass,.
1 ej20T closed deck short block,needs a good hone and home.
1 ej20TT long block,has wiseco pistons in it,took 1 out and it is cracked.
1 ej 20T short block,has arp rod bolts,arp head studs,has cosworth pistons,has had a hard life,bore not good,1 piston not good.
1 ej20tt long block,terminal failure,good as a door stopper
1 ej22 complete engine,200000ks,head gasket gone, service history known .
1 ej25 block,comes with new pistons,pins and rings.
2 ej20t early heads complete
1 ej20T inlet manifold RS
1 ej20TT inlet manifold
2 gen1 d/r awd gearboxes with shifters,cross members 3.9 ratio
1 rear diff(open) 3.9 ratio gen1
1 rear diff clutch pack lsd(off a turbo L series),its in a gen1 housing,4.11 ratio,new bearings and seals,needs to be shimmed
2 manual prop shafts
1 ej20T full wiring harness with ecu
1 ej22 full wiring harness with ecu
1 set of legacy chrome door handles
1 liberty awd wgn red boot lid strip,1 legacy one as well
4 16in gen3 rx alloys,tyres are shot
1 early forester spare wheel with brand new tyre
gen2 TT front rotors and calipers
gen2 TT air to air top mount a/c
gen 2 r/h fender
gen2 TT gt front bumper
gen2 TT radiator support panel
Make an offer on the parts
Christian 0419 928 306
Kappage
Post by Kappage » Wed Aug 19, 2009 8:57 pm
How much do you want for the Ej22 with a blown HG
chriSTIan
a
Post by chriSTIan » Wed Aug 19, 2009 9:27 pm
$150,missing injectors
Post by guyph_01 » Wed Aug 19, 2009 9:38 pm
how much for the lib rs lip chris?
Kappage
Post by Kappage » Wed Aug 19, 2009 10:13 pm
chriSTIan wrote:$150,missing injectors
A little pricey for a Ej22 with a blown HG and no injectors? Ill pass on it
chriSTIan
r
Post by chriSTIan » Sun Aug 23, 2009 7:31 pm
Guyph messsage sent
Offers on all parts
subarooster
Post by subarooster » Tue Aug 25, 2009 8:23 pm
wow... i'd love to hava walk around your shed one day. :) haha
01' Liberty B4.
chriSTIan
Post by chriSTIan » Tue Aug 25, 2009 9:48 pm
Thats the problem!
Ican't walk around in there anymore!!
I have also found some version3 cams
Return to “Western Australia”
