wtb: fwd auto ej gearbox
Post by D3V1L » Sun Jul 31, 2011 8:30 pm
hey guys anybody got an auto front wheel drive liberty or impreza gearbox?
and shafts if possible
cheaper the better
also need the flex plate and torque convertor
davo
niterida
Post by niterida » Sun Jul 31, 2011 8:36 pm
Don't dscount the AWD boxes - if you can find one of those they can be made FWD very easily - just block off the tail shaft and connect a couple of wires and hey presto.
Might be harder and more expensive to get an AWD box though :-(
Post by guyph_01 » Sun Jul 31, 2011 9:30 pm
I've got an AUTO AWD Box:) Also have two 2wd manual one out of a 91 lib the other out of a 96 impreza. I can get you the parts to convert your if you want:)
Maybe be happy to swap either of them with maybe some cash difference, depending, if you weld up my rear wheel carrier:p
No 2wd auto at the moment:(
Post by D3V1L » Sun Jul 31, 2011 9:50 pm
needs to be auto, and sort of needs to be fwd.
for sand rail
davo
niterida
Post by niterida » Sun Jul 31, 2011 10:31 pm
D3V1L wrote:needs to be auto, and sort of needs to be fwd.
for sand rail
davo
Grab Guy's AWD one and make it FWD. I'm not exactly sure what is involved but I would assume just putting a FWD rear extension housing or just a blank-off plate for the tail shaft output and connect the 2 wires and you're done.
Ring Doug at Stechnic in maddington - he will be able to say exactly what is required.
gx_rex
Post by gx_rex » Mon Aug 01, 2011 8:50 am
I'd be very surprised if Doug doesn't have one kicking around his backyard somewhere.
Post by RSR 555 » Mon Aug 01, 2011 9:04 am
Iz has a box and plate :)
Post by D3V1L » Mon Aug 01, 2011 9:44 pm
mr paul has come to the rescue once again:)
for the effort of making awd fwd, i found it easier to just wait for a fwd box to come up. lol
next questions i have are regarding the auto
can the box run without the tcu?
as i dont have any wiring or tcu for the box, and the motor is out of a rex. can i run the auto simply?
davo
Post by guyph_01 » Mon Aug 01, 2011 10:11 pm
I think i've got a auto Ej22 loom if that help with the TCU attached if you need it let me know:)
Post by guyph_01 » Mon Aug 01, 2011 10:12 pm
Again happy to swap for some welding skills:)
Post by RSR 555 » Mon Aug 01, 2011 10:37 pm
It will move the shafts but at about 30% of what it should. If you don't want to use a TCU then I'd use the vacuum controlled box from a Leone (L or MY) but I'd use the electronic box if I had the choice ;)
Post by D3V1L » Mon Aug 01, 2011 11:19 pm
needs to be an ej box paul. lol.
so who wants to help me wire it up? ahahaha
looks like im gonna have to look a bit more into my plans then lol.
davo
Post by D3V1L » Mon Aug 01, 2011 11:34 pm
well ive done a bit of research now...and i think im gonna be better off trying to make a manual gearbox work then wire in the auto
which is a shame, caus i really really wanted the auto to work :(
now i gotta do a whole lot of fab work just to get the shifter and clutch stuff working.
so next question, whos got a manual FWD box with flywhel, and clutch ?
davo
Post by TOONGA » Tue Aug 02, 2011 1:15 am
Ive got a 5 speed FWD box but no clutch or flywheel
Post by D3V1L » Tue Aug 02, 2011 9:44 am
That doesn't help me Jules lol. Also considering pauls idea of using vacume operated auto from an l series .......
Starting to loose touch With the subaru stuff!!
Davo
Post by D3V1L » Tue Aug 02, 2011 9:45 am
Davo
Post by RSR 555 » Sat Aug 06, 2011 7:53 pm
D3V1L wrote:That doesn't help me Jules lol. Also considering pauls idea of using vacume operated auto from an l series .......
Davo
I might have a 2WD auto box from an L somewhere around here?? Just need to clear out the junk first :)
Return to “Western Australia”
