85/86 3 plug manifold
coupe
Post by coupe » Tue Jan 24, 2012 11:04 pm
Hi Gang
Im chasing a 85/ 86 injected manifold for my vortex.
We were doing a engine build and change using a later model 4 plug engine. We got the later manifold off which was interesting due to the old rusted third manifold bolt on one end. We had to use a jack and a long bar to remove the manifold then weld a large nut to the broken bolt and super heat it when welding to release the bolt. But when we tried to remove the earlier 3 plug manifold off the original motor we coped the snapped off manifold bolt routine on both ends. Now we are having to see what our options are in removing the manifold.
Cheers Pete
Use The Fork Luke
Post by RSR 555 » Wed Jan 25, 2012 2:58 am
Hey Pete.. drop on into the shop. I'm sure there's a manifold or 2 that you can play with. I've also got a EA82T complete (I mean whole car complete) that you can buy when I strip it out. It was an RX sedan running gear fitted into a wagon.
coupe
Woohoo
Post by coupe » Sun Jan 29, 2012 10:55 pm
Thanks Paul.
But we got lucky today.
We got the bloody manifold off today with brute force and danglely bits lol.
The motor went in 2 hours later and now its bolting everything back on and see what happens.
Cheers Pete
Use The Fork Luke
Return to “Western Australia”
