Upgrade Shocks
Posted: Tue Oct 02, 2007 8:39 pm
by suba88
My shockies on the L series have never been changed so i was just seeing what is available and what is standard price for parts and fitting. I have king springs installed already. Does upgrading shocks make any difference to clearance or the lift of the car?
Everyone seems to get KYB shockies, how much are these and where are they best purchased from around Perth? I rang Pedders and they said they could only fit Comfort Gas shocks all round and the price ended up over $1000.
any info and suggestions would be great cheers
Paul
Posted: Tue Oct 02, 2007 8:46 pm
by Lapsed
Hey Paul.
You could purchase and self install for half that price. I recently purchased kyb 2wd struts for the rear (more lift that 4x4 ones) for about $85 each from auto one. Not sure on the cost of the fronts but shouldn't be to much. a set of spring clamps an a day's work and it is done.
chris
Posted: Tue Oct 02, 2007 9:04 pm
by suba88
did you just install the rears for any particular reason, or u gunna do the front ones soon? $85 seems to be a good price and you reckon get the 2wd shocks for more height, are they stiffer then the 4wd ones? can u notice the difference in the rear with your car?
Posted: Tue Oct 02, 2007 9:15 pm
by Lapsed
I just swapped the rears cause the 4x4 ones caused some sagging and tyre rubbing on compression. Haven't noticed any difference. Yeh would recommend the 2wd ones over the 4wd ones.
Posted: Tue Oct 02, 2007 9:52 pm
by 90brumby
dont fit 2WD front once tho cause they actually make the car lower at the front but ye by all means fit it to the rear
Posted: Wed Oct 03, 2007 1:16 am
by AndrewT
Good place to get KYB's from is WA Suspensions in Osborne Park. They are the WA disty for them.
Have a go at self installing if your keen, its fairly straight forward.
Posted: Wed Oct 03, 2007 4:39 pm
by suba88
so for the front i should get 4wd KYB shocks and for the rear get 2wd KYB shockies? thanks for advice fellas. Alot better than what Pedders offered me.
cheers
Posted: Wed Oct 03, 2007 10:17 pm
by howie
Im also looking at replacing 1992 L series springs. Does anyone know how far you can increase the length of the springs without doing other modifications? If so suggestions on supplier would be welcomed.
Cheers Mark
Posted: Thu Oct 04, 2007 3:15 am
by AndrewT
Get the Kings Springs to suit the L series, they are abit longer.
The Kings website has the local distributers listed I beleive.
Posted: Thu Oct 04, 2007 9:06 am
by mroberts
If you're replacing shocks, can I suggest
these while you're in there
Posted: Thu Oct 04, 2007 10:42 am
by howie
The information below is from an email i got from King Springs, a very prompt response it was too.
Cheers Mark
Thankyou for your inquiry,
We have King Springs Part No's KFFS-45 (front) & KSRS-02 (rear) to maintain factory std height.
These coils are designed with an increase in spring rate of approximately 25%.
RRP is $ 160.00 + GST per pair front
RRP is $ 160.00 + GST per pair rear.
Please contact the following King Springs Distributors for a price & availability in your area:
Autobarn, AutoPro, Checkpoint, Fulcrum, Repco, Supercheap, Bursons & most leading suspension specialists
Posted: Fri Oct 05, 2007 10:33 am
by howie
Contacted Lovells, the return email says that have nothing available for the L series subaru.
My question now is-- if you have replaced coil springs and gained more height which make and model did you use?
In Tech Talk section - Lifting a Subaru of this website
King Springs (probably because one brand is actually named King), they are about 33% heavier duty than standard and provide both more tension and vehicle height
Every one i have spoken to so far are able to locate replacement springs that are listed as standard height. Some are also listed as heavy duty.
Do the heavy duty standard height springs also raise clearance?
Cheers Mark
Posted: Fri Oct 05, 2007 10:55 am
by AndrewT
Yeah they do raise height but mostly because they are brand new (your old ones will be sagging) and also because under compression they will compress less becuase they are heavy duty.
I have seen L series subarus with Lovells springs before, whoever dealt with your enquiry probably got confused with MY series Subarus. Either that or perhaps they no longer manufacture that model. Doesn't matter anyway, general opinion is Kings are better.
Note - they have quoted you on SEDAN springs for the rear.
The part number for Wagon ones is KSRS-03.
If you have Munroe rear shockies you will need to order the Kings springs designed to suit them. KSRS03M. I think the spring base is slightly different on them.
**edit - somebody should probably move this thread to the suspensions section.
