I Need My A/c Regassed
chriSTIan
Post by chriSTIan » Mon Nov 12, 2007 6:00 pm
Does anyone on this board do car regas??for my gen1 lib,mobile would be good or SoR.
I am still on the old r12 gas
Thanx
Chris
tim_81coupe
Post by tim_81coupe » Mon Nov 12, 2007 6:46 pm
You will need to update to R134a gas. R12 is not available anymore. Are you sure your Lib runs on R12? I've only ever seen R134A on Libs.
Any good auto electrician can do it.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
SUBYDAZZ
Post by SUBYDAZZ » Mon Nov 12, 2007 7:42 pm
R12 is still available, if you know the right people. Some auto-aircon blokes will still top it up for you if they have some handy. Very few and far between I'd say by now.
SUBYDAZZ
timmo
Post by timmo » Mon Nov 12, 2007 7:45 pm
SUBYDAZZ wrote:R12 is still available, if you know the right people. Some auto-aircon blokes will still top it up for you if they have some handy. Very few and far between I'd say by now.
they use a replacement gas instead of R12, apparently has lpg in so most dont handle it. Also apparently dries the seals out. My '92 RS was
R12, just got it changed over to r134 last week by an auto elec mate, The receiver/dryer has to be changed and the 2 fittings on the valves used to gas it / vac the system down but thats it, i reckoned it was worth it
timmo
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
Post by Alex » Mon Nov 12, 2007 7:47 pm
i was thinking this yesterday...how often should we get the aircon re-gassed?
timmo
Post by timmo » Mon Nov 12, 2007 7:50 pm
when it stops working....;)
GU Patrol Ute
Honda XR400R
seagull
Post by seagull » Thu Nov 15, 2007 11:29 pm
Simon at welspool auto electrics is the man
Post by Subafury » Fri Nov 16, 2007 10:41 am
with my aircon, worked fine last summer, but now when i push the button i hear no whoosh air sounds (not from the A/C stuff anyway :p) or rpm drop when you normally turn it on. is this just a regassing issue or is my switch screwed?
Post by AndrewT » Fri Nov 16, 2007 12:12 pm
switch screwed.
The only real indication it needs regassing is when everything is apparently working fine but it just aint cold. Although there is usually a little window ontop of the canister thing down by the radiator where you can apparently see the gas, mine have always been too dirty to tell tho.
timmo
Post by timmo » Fri Nov 16, 2007 4:29 pm
some have a pressure switch - no gas means the compressor wont start
GU Patrol Ute
Honda XR400R
BENduro
Post by BENduro » Sun Nov 18, 2007 8:39 pm
Hmmm, mine works for about 2 mins then goes warm...press switch off and then on again and another 2 mins of cold air:confused::confused::confused:
Post by Subafury » Mon Nov 26, 2007 12:16 pm
i found the answer to my A/C problem whilst having a hunt through the wiring. found the blue n yellow fused positive wired wasnt attached to battery at all! all good now.
ITGRIPS
Post by ITGRIPS » Mon Nov 26, 2007 1:31 pm
i had mine re-gassed when i had my 200k service at RMS, they had to take the condensor out anyways to repair some bits. bloody cold now.
RMS service centre 9470 2444, if it needs fittings/parts to swap to the newer gas these guys would probably have them handy too. they are in Carlisle and arent mobile though
'97 WRX Hatch
'85 VK SS Brockodore
Return to “Western Australia”
