4wd tracks?
- subusurfer
4wd tracks?
gday does anyone know any 4wd tracks near Blackwood area in SA? looking for places to go locally to test out the L series, as well as a mates Patrol. cheers
[SIGPIC][/SIGPIC]1991 L series, 2" lift, 14" desert rats, perfect surf wagon in need of extra power
http://maps.google.com.au/maps?ie=UTF8& ... &z=17&om=1
http://maps.google.com.au/maps?ie=UTF8& ... &z=16&om=1
there is a couple, but as for legal, don't bet on it.. So beware.
The one near mount barker is a pretty long hill that is very clay'y. Dorset vale "Junk Tree" is a tiny playground. And the one in the middle is a small creek crossing that can sometimes get deeper then your windscreen.
Don't abuse the tracks please. And try to be as gentle and quite as possible. Don't want these spots closed down like every other good spot I knew of.
- subusurfer
really appreciated mate, thanks for posting the pics hopefully i can find my way up there and have a look. have you been up there much? as for the abusing of the tracks i'll make sure we keep it down and stick to the tracks. cheers.
- subusurfer
I've heard talk about these special CFS maps.. They are supposed to list all the fire tracks and other tracks that can be used in emergencies and stuff.. Never seen one though. We're pretty stuffed here in SA unless you know someone who has land.
Tried to find a track today near Gorge rd but when I got there my access was block. I'll try another at the top of the Parade at Sky in the week. There seem to be a lot of tracks at a beach north of St kilda at the end of a road called Shellgrit rd. You can find a lot of stuff with Goggle earth.
:p:mad:
;):D:-D:???::p- subusurfer
hayya im from up near blackwood as well...
its a bit of a drive from here but sellicks hill is ok, ive been up there once in my mates 45 L/cruiser, was good fun. theres some fairly steep parts and easy bits....from memory you just turn off sth rd at teh victory hotel and follow a fire track up the hill. (its been a while since ive been there)
- subusurfer
dylan wrote:hayya im from up near blackwood as well...
Yes, the track goes right up and over, then leads into Myponga. I'ved used it as a alternative route home some times.subusurfer wrote:after the two mud hills does the track continue? ive done the mud hills but wasn't sure if the track continued?
Awesome place that is. Been there twice. The comp track is fun, but last time he made all the peaks a bit higher and it was painful to here my exhaust drag on every hill. But now his making a couple more comp tracks, one of which is a tiny rally cross track and that was awesome fun.. It really shows how much better subies are at rally then big 4WD's. Although I popped a bead off because of the deep ruts and my tiny 27" kumho's....willkat wrote:4x4 park
http://www.loveday4x4adventures.com/index.html
