Moving - Garage Cleanout.
Locked
MY_STI
Post by MY_STI » Tue Aug 14, 2007 11:50 pm
Shifting down to Hobart shortly, Really need to clear the sheds.
CBF'ed posting stuff atm so its up for grabs if your in tassie. Mates rates on everything of course. Can do delivery to the main haunts.
Some items of interest?
1400 twin carbs, not quite complete.
L series lightened flywheel and clutch plate.
port-a-power, in box with various fittings, needs new seals.
- Deep breath - ea81 turbo, all there, two cracked heads.
Injec EM-1 aftermarket ecu, with complete harness to suit '81t.
High power coils, gt40r's, HEC 715.
eoi (undecided as yet) very good condition MY digi dash pad, beige, easy to swap to glf cluster.
Aus L turbo cluster.
new unused upper L radiator hose
new unused 4x ngk iridium IX BPR6EIX-11 for ea81/82
82t ignition control module.
late model 1600 manifold (well thats the guess, its not aus at any rate)
Set of MY seats,front and rear, from JDM sedan, 'tartan' centre cloth trim.
Toyota tercel SR tilt meter, fits nicely into the MY centre console, only goes to 30 degrees so the novelty wore off.
Plenty more stuff, will update anything else noteworthy if I think of it/find it.
If anyones after anything specific let me know and I'll keep an eye out as the junk is purged.
Side note: Finally fixed the idle issue with the wagon (thanks Ian) and some of you may be pleased to know the rev limiter now works. :shock:
'97 Outback - almost back to grandma spec operating condition.
"A day is never more than what you make of it."
Matatak
Post by Matatak » Wed Aug 15, 2007 12:15 am
another 1 not in Perth :(
and dont call it junk
wts with this Digi Dash pad wts that mean
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
subelover
Post by subelover » Wed Aug 15, 2007 8:18 am
bugger Sir Will i just brought a lightened flywheel ( off Cameron) and a clutch kit for my 86'sedan from bursons like 2 days ago ") oh well bt out of interest how much u want for them? cause i have a m8 down here that wants to go from auto to manual....in my old turboed sedan :) cheers BEN
Hoekl
Post by Hoekl » Wed Aug 15, 2007 8:19 am
Sif you moving to hobart. What you off there for? When you going?
Got any fandangal Liberty stuffs?
Prunes
Post by Prunes » Wed Aug 15, 2007 9:15 am
Wouldn't happen to have an passenger side front light cover for a single headlight brumby, or a bull bar, roll bar, or anything else I might need for and EA to EJ conversion both engine and gearbox will be converted, oh and L series low range gears.
Yeah I ask a lot, got big plans.
2002 Impreza GX Hatch: Dents, Scratches, Missing inside wheel arch, Barely attached front bumper.
1983 Brumby: Currently being rebuilt.
MY_STI
Post by MY_STI » Wed Aug 15, 2007 9:23 am
The junk is the stuff that hasn't been listed!
'Digi dash pad' is the whole dash, vents, glovebox etc. Not cracked, faded or scuffed. the digi dash cluster can easily be swapped for the glf dash cluster ('analogue', with tacho oil pressure, voltage.)
Ben, flywheel and pressure plate sorry, if I find some more clutch/driven plates (you never know!) I'll throw one in as well. How does $50 grab you?
Joel, Mainly hardware, need engine parts? Have to do something about tims liberty so there might be a whole swag of lx parts. (Pending)
MY_STI
Post by MY_STI » Wed Aug 15, 2007 9:31 am
Might do, I'll jot it down on the whiteboard.
Have a high pressure fuel pump you can have ($0), out of a camira.
No L low range gears, the demand seems greater than the supply at the moment!
Have other odds and sodds that will be handy. I'll make a pile for you.
Also have an incomplete 2" MY lift kit, can make the rest if your interested.
Prunes
Post by Prunes » Wed Aug 15, 2007 10:48 am
Well looking at he plan I think I will need MY top and Lib bottom on my front lift blocks as I'm looking to change to lib struts, Let me know how you go with any ods and ends I'm sure lots of things may come in handy as I have nothing as of yet.
Hoekl
Post by Hoekl » Wed Aug 15, 2007 11:00 am
Hey there. Well my third gear is a bit notchy. I think its a syncro. Does tims car have a dual range gearbox? Coz i was thinking it would be easier replacing the whole box rather than a syncro?!? Opinion?
Hoekl
Post by Hoekl » Wed Aug 15, 2007 11:10 am
oh, and im thinking that im getting pretty desperate for sunvisors, as the floppiness is driving me insane. So if any of them are up for grabs still, let me know:D
Fatz
Post by Fatz » Wed Aug 15, 2007 11:18 am
im getting desperate for food. im starving
and a 4.44 diff
Rob
Post by Rob » Wed Aug 15, 2007 4:12 pm
Fatz wrote:im getting desperate for food. im starving
and a 4.44 diff
i am cooking u tea when i come down
Destro
MY_STI
Post by MY_STI » Wed Aug 15, 2007 4:40 pm
I would be starving to if I had just brought what you have Adz!
Why buy food when you can spend the last few $$ on 98RON? ;)
Trent - Also have some 5 stud gear, not quite ready to let that go yet but can keep you informed, may well find spare spares as the smoke clears.
Joel - have a lib dr box in the shed atm, but its kind of spoken for, will let you know if things change. Acctually, might drop round in 10 or so.
Macca2305
Post by Macca2305 » Thu Aug 16, 2007 9:28 pm
hey mate i am interested in the 2'' lift how much do u want for that and how much is missing? also have you got a brumby towbar?
Ben
Post by Ben » Fri Aug 24, 2007 9:41 am
There is a For Sale section for selling.
forumdisplay.php?f=34
Please watch before posting!
Locked
Return to “Tasmania”
