An EA82, a wallet, and a mission
tim_81coupe
Post by tim_81coupe » Fri Feb 03, 2006 1:08 am
Woob wrote:as for the VRS kit, ill go order it tomorrow.. other than head gaskets what will it contain? getting a pack of fresh head gaskets with the motor so i dont particularly need them
The VRS will contain:
Head Gaskets
Valve Cover Gaskets (aka rocker cover gaskets)
Valve Stem Seals
Valve Cover Washers (for the little rocker cover bolts)
Cam seals
Inlet Manifold gaskets
Exhaust manifold gaskets
and maybe a Distributer O'ring too.
There might be something else I've forgotten... not sure atm.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Woob
Post by Woob » Fri Feb 03, 2006 9:43 am
woah thats awesome! :D saves me going out and getting gaskets individually :)
Woob
Post by Woob » Sat Feb 04, 2006 1:47 am
just scored an RS Lib intercooler :D going to pick it up on sunday when i get the engine.
after i get the valve kit i think ill pretty much be ready to swap the engines \o/
tim_81coupe
Post by tim_81coupe » Sat Feb 04, 2006 2:41 pm
Did you score the entire setup? That's intercooler, front radiator and water pump.
If you've only got the cooler part I think I've got the rest somewhere.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Woob
Post by Woob » Sat Feb 04, 2006 4:35 pm
aah yeah, only got the cooler, dont have the rest now you mention it.. forgot the rs lib cooler has a water system on it
Return to “Trouble Shooting”
