noise in the front of my L series.
Punisher
Post by Punisher » Wed Mar 30, 2011 12:35 pm
Having replaced both outer cv joints and wheel bearings I thought I had got on top of the noises from the front of my 2004 L Series wagon.
Now it has developed a noise that kind of sounds like the pad rubbing from a hot spot on the disc but I dont believe its the disc. It only makes the noise when under load, accelerating or decelerating. If it coasts with no load, no noise. Im thinking it is either a gearbox bearing or an inner cv joint.
Any ideas ?
Post by RSR 555 » Thu Mar 31, 2011 3:35 am
2004 L.Series is pretty special :p
I'm putting my money on loose CV nut. Best way to check is jack up the front of the car and try and rock the wheel by putting your hands at 12 and 6.
Punisher
Post by Punisher » Thu Mar 31, 2011 2:49 pm
lol ... yea, what I ment was a 94 L series :p
I checked the front out, everything seems tight.
How often do inner CV's generally last for ?
Post by RSR 555 » Fri Apr 01, 2011 12:41 pm
Yeah.. I kinda gathered that by your signature :)
Inner CV joints can last the lifetime of the car if cared for. Check the rubber boots and also look for oil/grease splated around the areas.
Punisher
Post by Punisher » Fri Apr 08, 2011 2:36 pm
Actually, you might be right about the CV nut. It didnt feel loose but when I took the nut off to pull the drive shaft out, it came undone without any effort.
I checked the inner cv and that seems fine. Took it for a short drive and no noise sofar.
Return to “Trouble Shooting”
