I have a 91 FWD Liberty. I've noticed a grumbly whine that seems to be coming from the passenger side rear. Several times in the past couple of weeks, I've jacked it up and spun the wheel by hand. There's no play, no grumble, no roughness that would indicate a crook wheel bearing. Nor on any of the other wheels for that matter. After a drive no hub is significantly hotter than any of the others. So apart from the sound, I'm tending to eliminate a wheel bearing as the culprit.
So, are there any people out there with any other ideas?
