Coolant leaking near sump?
LIFTED
Post by LIFTED » Sun Feb 10, 2013 12:24 pm
I just replace a small leaking hose connecting onto the thermostat and I have now noticed another leak.
But this one looks like it's coming out from where the sump bolts onto the engine. One drip every 15 seconds $20 worth of coolant just dripping away:mad:
I'll attach a pic
Any ideas where this leak might be coming from?:confused:
[SIGPIC][/SIGPIC] ..........................................92 Lib 98 Foz 99 GT Foz :roll: ..................................................
tambox
Post by tambox » Sun Feb 10, 2013 12:28 pm
Gravity rules, is that a green drip on the timing cover? Below the waterpump?
Follow the trail.
L serious, still.
Post by TOONGA » Sun Feb 10, 2013 12:31 pm
Is this the liberty or the forester?
Looks to be coming from the hex head plug in the middle of the picture. I would try a tube of silver seal or the one that is copper flakes in a bottle. both products are around 10 dollars.
Battlewagon
Post by Battlewagon » Sun Feb 10, 2013 2:56 pm
Personally, I'd avoid any type of sealant that has metal flakes in it, I've been there and destroyed and seized the water pump with that stuff.
Of course, it did mean the leak got fixed, as well as the timimg belts...
Post by TOONGA » Sun Feb 10, 2013 3:04 pm
I didn't notice the coolant on the timing cover, it looks like you may be up for a new water pump :(
Post by AlpineRaven » Sun Feb 10, 2013 4:00 pm
Since its where the water pump side is - i would say its coming from the water pump. Timing Belt has to come off...
Other place would be these hex head bolts but uncommon for it to leak there. I have also noticed a small green drip just next to the thermostat - that is closer to where the water pump is.
LIFTED
Post by LIFTED » Sun Feb 10, 2013 9:49 pm
Yep gravity sucks.
Jules yes it's my Liberty:(
Yes it is a drip on the timing cover but it's seems to be more of a dried up drip as i it's quite thick and "cluggy" whereas the other stuff near the hex plug is fresh I too thought/hoped it may have been from the hex plug.
Post by RSR 555 » Tue Feb 12, 2013 4:55 pm
Mike, having a closer look at the pic, it appears that the coolant is running along the sump (as I see some up forward as well), so my best guess without seeing it first hand would be the water pump.
Maybe someone sold you a dodgy car??? haha
I would give it a good wash down with degreaser and go for a run around the block and then check it again.
Post by AlpineRaven » Tue Feb 12, 2013 5:10 pm
RSR 555 wrote:Mike, having a closer look at the pic, it appears that the coolant is running along the sump (as I see some up forward as well), so my best guess without seeing it first hand would be the water pump.
I second that too.
LIFTED
Post by LIFTED » Thu Feb 14, 2013 9:32 pm
AP do you second the dodgy car bit.
Post by AlpineRaven » Thu Feb 14, 2013 9:36 pm
LIFTED wrote:AP do you second the dodgy car bit.
No - I was referring to wash it down and have a closer inspection.
Post by RSR 555 » Fri Feb 15, 2013 12:50 am
AlpineRaven wrote:No - I was referring to wash it down and have a closer inspection.
LOL.. sure AP.. we know what you were referring to :p:p:p
Return to “Trouble Shooting”
