Anyway Bianca is running great and the other day i finally got off my arse and put the A/C back in. It's nice and cold, engine is ok once moving (even up hills!) but don't you dare try and take off with it on haha
I have two problems. The first is my fan speed seems to be a little slow, i'm wandering if there is any way to make it faster (A/C guy said it was slow and compared to mum and dad's it is definitely slow). For when i need that extra kick. I looked for number 11 on the dial but it wasn't there.
Secondly, I had to re install the evaporator and hence remove the glove box which is still out of the car. I have since noticed that i can't change between fresh air and circulate. It just stays on circulate even when the button is pushed. Problem is there isn't enough vacuum going through that little hose that connects to the module on the fan that changes it.
Thanks in advance
Cheers Cam
