heater and fan problems
hi i am having trouble with my subaru brumby 90 model i was driving one day and my fan stopped and now my fan and heater and ac doesnt work i have put a new fan in a new switch but there is no power going to it please i need help
Sorry to come across smart but, have you tried the fuse? Also measure the resistance from the fuse box to the wiring connector(on the output side of the fuse box to the power side of the fan wiring plug), should be close to 0 Ohms. Also just try putting an earth to one side of the connector and 12v to the other and check the fan spins up. Let us know how it goes.
"Claudia"
"Claudia"
Have you checked the resistors for the fan speed control? The unit is mounted in the heater box next to the clutch pedal.
Are you getting power to the fuse?
There may also be a relay under the dash for the aircon and fan that could have died. Had issues here with my 83 wagon. Mine was mounted above the headlight relays.
'97 Outback - almost back to grandma spec operating condition.
"A day is never more than what you make of it."
