EA81 or EJ in Brumby
- mud_king91
yes sorry 8.7:1steptoe wrote:Think revmax may find 7.7:1 ratio is EA82T , EA81's are already close to 9.0:1
- Silverbullet
Can I suggest, if you go down the road of rebuilding the 81, don't skimp on ANYTHING
I mean, buy new pistons, new conrods, bearings and rings of course, get crank linished, heads faced, maybe valve job if yours are stuffed, rebuild or replace carb with a new one...Don't try and get away with the minimum of spend, I did and you only have to read my rebuild thread to see where that ended
Also the usual stuff like don't rush, be patient, if you have to wait a week for a tiny part to arrive then wait don't try and push on without it. But I'm sure you know all that
- Brumby Kid
Didn't have time to use the chemytech today (Another week). What i did learn is of course my battery was flat so i charged it. Eventually it turned over, i then disconected the charger and let it idle for 20 mins or so. I then turned it off and tried to turn it back on, NOTHING. I have filled it with distilled water and left it charging overnight. I was told if nothing tomorrow, check the alternator (which i think is ok) if not its a dead battery
- mud_king91
Try INOX battery conditioner... works everytime for meBrumby Kid wrote:Didn't have time to use the chemytech today (Another week). What i did learn is of course my battery was flat so i charged it. Eventually it turned over, i then disconected the charger and let it idle for 20 mins or so. I then turned it off and tried to turn it back on, NOTHING. I have filled it with distilled water and left it charging overnight. I was told if nothing tomorrow, check the alternator (which i think is ok) if not its a dead battery
- Brumby Kid
What does it do? That would be another great fix to by me some time before i have to do something. Just like the chemytech.mud_king91 wrote:Try INOX battery conditioner... works everytime for me
- Brumby Kid
- mud_king91
- Brumby Kid
- mud_king91
- Brumby Kid
- Brumby Kid
- Silverbullet
Depends on what you get I guess. As a rough idea, I got my bores honed, crank linished, new rings and bearings, plus an engine block gasket set (not head gaskets) for $190. Depends where you go too most likely, I went to a local engine shop. Took it all in one morning and got it back the same day. You will most likely need a re-bore though, for the new pistons.
Where's littlewhiteute when you need him, he's got all the answers
- Brumby Kid
Silverbullet could you please PM me with where you went for what. And if you would recommend them to me. Thanks much apriciated Cam
- Brumby Kid
Definately going to rebuild the EA81, its just a matter of when (probably most of it will get done during the christmas holidays). Time to start collecting parts. The upgraded version rather then standard. New pistons, no idea where to get them. Im hoping most can be bought at Autobarn. All advice and tips much aprichiated. Im now off to look at Silverbullets thread and learn as much as i can. Hopefully lunch doesn't end too soon.
Cheers Cam
Cheers Cam
- Silverbullet
- mud_king91
- Brumby Kid
i have only been half following your thread Sam, what happened? Was it the slugishness, and new carbys manifolds etc? What was it in the end?
Mud_King91 sorry no idea what happened to your rodeo, got a thread and or pics?
Cheers Cam
Cheers Cam
- mud_king91
