Fuel pump dying??
Fuel pump dying??
Hey guys.
Been having a bit of trouble with my old girl over last couple weeks. Motor is standard ea81.
First problem is the idle. It doesn't want to idle at all, even with the manual choke half to three-quarters of the way open. I have to keep the accelerator on for it the idle.
Second problem is as follows. Does not want to maintain a steady speed. It will continue to slow down even with the accelerator flat to the floor. It just chokes and dies.
Both fuel filters have been changed round 10,000k's ago along with dizzy cap, rotor, plugs and leads. Was thinking it could be fuel pump dying, or maybe the carby needing a rebuild.
Cheers for any help.
I had a fuel pump die on me once, but mine idled fine. It just used to cough and stutter going uphills, and when heavy on the throttle. It just didn't flow enough anymore. I rebuilt my carby before I worked that out.
If its not idling because of the fuel pump it would have to be virtually not flowing at all or a blocked line.
But i'm no mechanic
But i'm no mechanic
Doesnt hurt to swap over to another fuel pump? - grab one from wreckers..
When was it last time it was overhauled? It might be due? - I think they strip and clean every single bits.. not sure, Ive never gotten an carby rebuilt....
- BaronVonChickenPants
You can do it yourself, kits are less than $50 last time I looked (a while ago now) but depending on the model of manifold on your EA81 you can fit the auto choke EA82 carb, I would get one of these fro a wrecker, rebuild that and fit it.
The bonus being you get an auto choke and you car isn't out of order while you rebuild the carb.
If you wanted more power you could rejet it to 120 primary and 210 secondary jets, reliably ran this setup for many years on my EA81.
Jordan.
Jordan.
