Exhaust Gasket and Stud Replacement
Posted: Wed Oct 12, 2005 3:43 pm
by Tim82
G'day all,
after the weekend ive been left with no gasket or studs on one of my exhaust to engine pipes.
having not replaced one before is there anything to look out for? is it just a case of putting in new studs and gasket, will i need any sealent or the like.
Cheers Tim
Posted: Thu Oct 13, 2005 9:11 pm
by Kev
Why is there no studs?
Sometimes the studs can act like bolts when the nut is rusted onto them. This could be good because they may have vibrated loose.
If they didn't vibrate loose you may have hit something & stripped them in which case you will need to retap for new studs.
The other thing that can happen is that they sheered off. This is a real pain because you will need to use something like an e-z-out to remove them. I have always had troubles using them.
Posted: Thu Oct 13, 2005 9:15 pm
by Kev
Why are there no studs?
The gaskets look like they are made from the same material as most manifold gaskets, in which case they should seal ok. I have heard a lot of Suba's with leaky exhaust gaskets so other people may have more informed ideas.
Posted: Thu Oct 13, 2005 9:59 pm
by Tim82
Yeah the gasket blew out and then the studs must have rattled loose on the 150 km drive home, it was bloody noisey!
ill have a look at them this weekend shouldnt be too hard to replace
Cheers Tim
Posted: Fri Oct 14, 2005 12:34 pm
by choinka
Similar thing happened to me with my old MY. But I had sheared the bolt. Check inside the hole with a torch to see if they haven't sheared and there's enough thread. Exhaust place just drilled them out and helicoiled new ones in. Never had a problem after that
Richard
Posted: Fri Oct 14, 2005 1:06 pm
by Guest
Yeah, that's what had to do to an old EA81, drill out the old thread, tap in a helicoil thread and put in a helicoil.
Probably going to be stronger in the long run than the old alloy thread too.
Posted: Fri Oct 14, 2005 7:39 pm
by stamp_licker
ea82 heads have 2 set of threaded stud holes.if you tear one use the other but then again helicoils r good.
