weber carb fitting questions need answering asap
Posted: Sat Mar 04, 2006 9:01 pm
by grytvikken
im just got motivated and started fitting a webber carb to my ea82 and have a couple of questions .....no doubt more will follow.
1/ after pulling the original carb and manifold off to fit the set up i bought i noticed that the vacuum advance on the carb needs to plumbed in alas cant remember where the tube from the distributor goes???? any advice as to where the hose goes from the distributor....
2/ power steering pump gets inthe way of the manual choke setup. any advice on this or should i just remove it and not run a choke.
cheers
Posted: Sat Mar 04, 2006 10:02 pm
by stinky
1/ dunno
2/ Run without the choke, I never really needed to use the choke on my old webber'd wagon.
Posted: Sat Mar 04, 2006 10:45 pm
by grytvikken
stinky wrote:1/ dunno
so stinky did you find not having a choke caused issues when starting on cold winter mornings and as for the vacuum question .....no memory of wht you did with it? cheers
Posted: Sun Mar 05, 2006 11:19 am
by Bobbrumby
1\ You need to hook up a line from the ported vac ports near backside of carb at its base to the vac advance can on dizzy.
Posted: Sun Mar 05, 2006 6:49 pm
by grytvikken
hey bob do you mean its the one that is on the side of the carb itself ? i have a vacuum port that has a hose that goes from the base left hand side to a square part of the carb where i think the float bowl is??? sorry if i sound vague but the carby is something i know sweet FA about. if it is this could i add a T piece and run a hose to the distributor.
if i sound confused ......i amm!
cheers
