RWD L Series
RWD L Series
Hi All.
I am considering converting the L Series to RWD (never goes offroad, buying a dedicated offroader)
I have heard the process can be as simple as lopping off the front drive shafts but I am sure the process is a fair bit more complicated than that.
Can anyone shed some light into how this is done?
Thanks
Thanks
Sounds good.TOONGA wrote:yes it is that simple 2 old outer CV 's with good splines and threads you can put dummy boots over them if you like
pull out drive shafts replace with outers only put your gearbox into 4wd and hey presto rear wheel drive
The car is mainly doing freeway/city driving and I would much prefer RWD over front wheel drive (because my other cars are commodores, FWD just doesn't feel as nice to drive)
Will it do any damage to the gearbox or diff considering they have both been built for 4WD
- little_red_L
Ive heard that doing this can cause undue stress to the rear moustache bar. It is pretty flimsy and not designed for 100% power. extra bracing and/or a custom sway bar might be in order to prevent torque twisting it. all this also depends on how you drive too.... drifting in this new RWD-guise, not reccomended.
Red 1990 L series sportswagon: sports muffler, 4" lift, pod filter, powersteer conversion, pug 14's and a coupla stickers. with 27"s on their way. Everything else? Standard. For now....
ahhh but it would be very difficult to notice that it had been converted to RWD, and depend what wheels you were using it would be as simple as sliding a screwdriver or spanner thought the rim and stopping it turning right.steptoe wrote:Great anti theft leaving it in FWD!! And often wondered how to you do/undo the big 36mm nuts when no link to gearbox to resit either way, just rely on handbrake?
the car will handle like a pig though, and not the commodore type not a enough power from the 4 cylinder.
i would think about doing the conversion i think it would be different, but it would need the EJ and rear disks
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- brumbyrunner
It's been done plenty of times.
Like TOONGA said, pull out the front driveshafts and throw in some bare front CVs. You can remove the guts of the CV or just leave it in there.
Quick and easy thing to try, and easy to put back to original when you find it handled better as FWD.
I find the biggest problem is the 3 rear diff mounting rubbers. They're very soft (especially if original) and allow the rear diff to move around, absorbing power and making a racket under acceleration.
Settlement Creek Racing
as above, it's been done many times before and is easy to do.
I found it improves the handling and balance through corners, and makes it a bit of a laugh to drive through the hills. I've always hated front wheel drive understeer and loved having the rear wheel drive "steer by throttle" to balance the car with (power slide with an EA, yeah right...HA HA HA HA.....)
BUT I'll warn you now, the transfer gears in the box are the weak point and will fail sooner or later. Mine lasted 6 months or so and then went without warning or provocation. I was just pulling away quietly, and BANG....
the diff will handle it, but the mounts mentioned above will go too, but that can be overcome.
amen....i ran rwd with ej22 for a while...only cos i had a blown front cv. Horrendus noises from the arse end....spesh when trying to drop 1stbrumbyrunner wrote: I find the biggest problem is the 3 rear diff mounting rubbers. They're very soft (especially if original) and allow the rear diff to move around, absorbing power and making a racket under acceleration.
Yes i had my Brumby with the RS turbo and old awd gearbox welded centre diff removed front CVs as described. With a VLSD also
Was a whole lot of fun untill it rained then it was down right insane
The brumby being very short it wanted to swap ends very fast and I mean fast could not get quick enough to catch it sometimes.
Took me a while to get used to it. Even still you had to drive so carefully in the wet.
I remember entering the free way at about 120 just accelerating to keep in front of a truck then having to steer the thing to keep moving in a straight line not much fun when your not "driving the car".
In the wet you just pick any gear and it just changed how fast its wheels spun.
So many optioins not enough time or money
- maxxair
remove atleast one (1) CV and you're away. works well. handles better on hiway (no tracking ala fwd) just dont bump the lever and you're good.
heres a vid of my 'little red' on its final day out. wouldnt die, even with its terminal illnesses. poor ol thing copped a floggin and NO maintenence besides tyres. refused to die even with leadfooted doughies in Lo-range. coughed up some wicked clouds tho.
RWD is FUN!
http://www.youtube.com/watch?v=jOxmb2WZPPg
RWD is FUN!
