Brumby exhaust steam up
Brrrummmbeee
Post by Brrrummmbeee » Thu Aug 19, 2010 8:00 pm
The little EA81 is pumping gaseous coolant out the exhaust. No oil in coolant or vice versa. Before I tear a head off any ideas on what else to look out for? She's running on 3 & 1/2 cylinders, LHS bank methinks is down.
LP
Post by RSR 555 » Thu Aug 19, 2010 8:39 pm
Inlet manifold gaskets :)
maxxair
Post by maxxair » Thu Aug 19, 2010 9:36 pm
head gasket, try putting 'metalic seal up' into the radiator. hopefully this will stop it, until next time you overheat it, that is
Cheers, Rohan M.
Brrrummmbeee
Post by Brrrummmbeee » Fri Aug 20, 2010 1:35 pm
I'll try the inlet manifold gaskets, and failing that maybe add sealant..
Thanks,
LP
Post by El_Freddo » Fri Aug 20, 2010 7:23 pm
Its not a wet spark plug again when climbing hills is it?? :p
I'm hoping its what RSR said ^
