Help L Series running on only 2 cylinders
- richard the fish
Hi All my trusty 93 L series is running on 2 cylinders only.
The car has 235,000km and is quite well looked after, I change the oil and filter every 3 months, and flush the cooling system twice a year. The carb was fully rebuilt last year so i do not think this is the problem.
The auto choke has never been connected.
A couple of weeks ago it started idiling very rough, all the plugs are sparking but when I pull the 2 drivers side leads off it makes no difference, just runs rough, could this be a timing belt problem as it has not been changed since 120,000 ? If so can I tell without pulling it apart? there seems to no difference in the power.
Thanks
Richard
Thanks
Richard
could well be timing. May have skipped afew teeth.
only way to tell this tho is to remove the timing belt covers and have a visual check.
other than that, make sure your dizzy and cap are all okay.
So you've had the plugs out and seen them sparking against the block (or something like that) ?
Maybe it just needs the plugs cleaned and the gap checked or even replaced. Have they been in service for a long time?
- richard the fish
- richard the fish
If they've been there for years then maybe it's worth changing them just to rule it out. You wouldn't want to blow too much time investigating other things if it turns out to be just the plugs. They are cheap and you may as well change them if the existing ones are years old.
Otherwise, if they are sparking properly it must just be at the wrong time, so a timing issue. I'd investigate spark timing (the dizzy) first. Got a timing light?
- richard the fish
