hot brumby
joedirt1
hot brumby
Post by joedirt1 » Wed Oct 20, 2010 6:44 pm
89 brumby ea81 -new water pump,thermostat,rad,timing good,no bubbles in rad or oil starting 2 shit me dont tell me im ripping heads off this w-end.
spike
Post by spike » Wed Oct 20, 2010 6:54 pm
its a subaru =)
if its not the hg dont really worry about it, check that the fans work properly and are fully shrouded
joedirt1
Post by joedirt1 » Wed Oct 20, 2010 7:01 pm
fans all good any other way 2 diag crak head or gasket before major op
Post by El_Freddo » Wed Oct 20, 2010 7:08 pm
I'd make sure that your temp gauge is accurate for a start, then go from there.
Also make sure it is correctly tuned, if running lean it will run hot. This happened to me in my brother's mini - only because the carbie was coming loose!
daza
Post by daza » Wed Oct 20, 2010 7:17 pm
Take it to a radiator shop and get them to test it.
Daza.
