washed engine, gain in power... wtf?
Posted: Tue May 31, 2011 2:26 pm
I really can;t figure this out, and it's seriously bugging me, so I could use the collective wisdom here.
I decided that i needed to give the car some TLC, so schdueled a day and did some research - ive been changign my own oil, but this time around i wanted to do the spark plugs and the like.
The context (considered causes):
-- the last oil change had been some 8000km prior - it had looked fine ( i check every second fill up ) but it rapidly got very dark around here - i was on holiday and it had to wait another 100km. I could definately feel something was up.
-- spark plugs had been changed 20000km prior
-- i had hit a ditch a bit hard - some scrape ...maybe muffler? no immdiate difference.
-- wheel alignment hadnt been changed in 18 months. hadn't felt off.
So, im sure that made someone cringe, but i assure you, im getting into it on ontop of it now - very fun stuff.
So i've got in and gotten new wheels, aligned and balanced. I also got into the car and cleaned everything.. including the motor. It was pretty straight forward (plastic bag over the dist'cap), and added some degreaser into the mix for some areas (mainly the leaft side around the pullies and near the air-con area and under the air-intake plastic pipes). I then went on the replace the spark-plugs (only a little white on them). Changed the oil.. wasnt horrible, but deffinately due (black, not gritty), which is exactly 10-40w (valvolean protection stuff). flushed a little extra through it too. changed the oil filter... and all was well - started up happy as pie.....
That was when i noticed the engine had a louder suby tick to it.. it sounded a little more coarse. After 2 drives it seemed to subside, so i adjourned it was moisture.... then the third trip i decided to boot it... low and behold it hits 3 500RPM+ with the pedal to the floor and the engine kicks in and /muffler sounds louder. not only that, but it was absolutely flying - now hits 130 verrrry easily. I could almost say that it sounds like an after market muffler is on it. its REALLY weird. It only happens when the pedal is to the floor - it can be doing 4000rpm and its normal/quiet.
SO, after that essay, any ideas?
pics:
the car: MY2001 impreza GX 2.0L non-turbo
pics:
