Brumby Oil pressure lamp stays on longer than it used to.
I have noticed over the last year or so that my oil pressure light stays on for about two seconds when I start the car in the mornings. It used to switch off straight away. Should I be worried? - (Oil is at the right level and good quality)
I notice this happens when Im due for an oil change
A new oil pressure switch for about ten bucks is a start - OPS008 or something close in Tridon, maybe it was OPS006. My EA81 has about 450,000km on it , gets oil chang every ten thousand km, does same, with the exception of this morning oddly enough did not even start with flat battery left out in the COLD
- brockharro
- Pommiebrat
Mate,
I had an engine that did this and got progressively worse. Checked oil level, changed oil and filter but still carried on. Eventually the engine let go catastrophically - no 3 piston went through the crankcase. On inspection turns out the guy I had bought it from had put some crap in it when running it round his farm which had slowly clogged the oil pick up pipe and strainer from the sump to the point where no oil was circulating. For the sake of a new gasket might be worth dropping the sump and taking a look - you can do it with the engine in place.
John
John
