Brumby exhaust studs falling out
Spin
Post by Spin » Thu Aug 11, 2011 3:09 pm
Hi, Is it a common problem that the Brumby exhaust manifold studs vibrate loose and fall out over time? If so is there a fix for this other than locktite solutions? Thanks Spin
BBoypebs
Post by BBoypebs » Thu Aug 11, 2011 7:50 pm
Hi there. Had the same issue. The treads were worn.
Fixed it by recoiling the threads and new studs with strong loctite.
[SIGPIC][/SIGPIC]88 Subaru Brumby (Currently being restored.:twisted: 84 brumby 2 inch Lift(very rough, Big tires)
Landrover series two. 186 holden banger under hood.
Spin
Post by Spin » Thu Aug 11, 2011 11:01 pm
ok thanks. Spin:)
Post by TOONGA » Fri Aug 12, 2011 8:12 am
the other way is go to a bigger size stud but even then the stud can vibrate out unless loctite or some other form of holding agent is applied.
Post by steptoe » Fri Aug 12, 2011 8:55 am
silicone is also good to stop them vibrating loose if you have good threads. Think M8 1.25 is standard thread, same as Toyota studs I tell exhaust place when sourcing more studs @3 bucks each
Post by RSR 555 » Sat Aug 13, 2011 12:57 am
Yep quiet common if not done up correctly. It's always good to loctite the studs in, as long as the thread in the block is good or you're going to need to either helicoil a new thread or use a larger stud. I have in the past used a stud that is M10 one end and M12 at the other (thus eliminating the need for a helicoil kit)
Spin
Post by Spin » Sun Aug 14, 2011 12:03 am
ok some good suggestions. Thanks everyone. Spin:)
