is the 93 l series and leone the same thing
gday trying to find front wheelbearings for my 93 L series 4wd and and repco, auto one etc dont have a listing for the l series only the leone are they the same car i am a newbie to subarus but loving them if anyone can shed some light cheers
As long as you buy them for a Leone that is between 1985 and 1994 with the 1800cc EA82 engine, then you'll get the correct bearings. When they give them to you, make sure the 2 seals are different sizes. The earlier Leones (1979-1984 1800cc EA81 engne) have the same size seals.
mate your a legend thanks very much for the info cheersRSR 555 wrote:As long as you buy them for a Leone that is between 1985 and 1994 with the 1800cc EA82 engine, then you'll get the correct bearings. When they give them to you, make sure the 2 seals are different sizes. The earlier Leones (1979-1984 1800cc EA81 engne) have the same size seals.
So... no difference between FWD Leone and 4WD wagons, maybe not in the bearings, what about the inner seal.... all the same...?
rousy there are some good sites to look up part numbers ...one is rockauto.com - a very comprehensive US site that has many part numbers, with pics or links to description. Compare FWD to 4WD part numbers to se if they are same etc. Don't use the prices s a guide to Oz prices though
No probs.. anytime.. that's what we are all here forrousy88 wrote:mate your a legend thanks very much for the info cheers
Veales, Repco and Coventrys have never asked me if they (front bearings) are 2WD or 4WD.. so to answer your ?, I'm going to have to say yessteptoe wrote:So... no difference between FWD Leone and 4WD wagons, maybe not in the bearings, what about the inner seal.... all the same...?
In fact, I've only ever seen the differences in the internal spline count (on the CV shafts) between 2WD and 4WD ones.. the outer spline and part on the CVJ where the seal runs on are all the same.
