04/00 forester ecu location???
2coupedup
Post by 2coupedup » Wed Sep 07, 2011 11:57 am
WTF, not on the floor... not under the dash... not connected to any wiring...
just ripped apart the entire front end of the 2000 forester and collected all the wires and plugs, no cutting, and anything that was plugged in that could be left plugged in an unbloted instead was...
have the ECU IMM, Cruise unit, Air bag unit, keyless unit, fuse holders, relays, diagnosis plugs etc...
started it up drove it onto a truck, got home, drove it off the truck, jacked it up, ripped it apart...
i have 7 days left to do my conversion and i'm stuck lol...
not funny really just F'N annoying
anyone.... help... please...
cheers
apg39
Post by apg39 » Wed Sep 07, 2011 1:25 pm
On the footwell of the passenger side. Its under a metal plate on the angled front part from memory.
Andrew
2coupedup
Post by 2coupedup » Wed Sep 07, 2011 1:36 pm
nope... no metal plates and no wires going there...
wires on the drivers side running along towards the rear but i gather thats just the rear loom for lights etc
Post by TOONGA » Wed Sep 07, 2011 2:51 pm
according to my FSM collection it will be in the back on the right hand side under a panel
this should help
http://jdmfsm.info/Auto/Japan/Subaru/Fo ... %20Manual/
If it isn't there then it is up under the dash on the passenger side.
Post by Alex » Wed Sep 07, 2011 3:09 pm
behind the glovebox?
or else its in the center part of the dash behind the stereo?
Post by TOONGA » Wed Sep 07, 2011 3:14 pm
after a quick search of the FSM's this should be where yours is
passenger side under the dash (behind the glove box?)
hope thats right :)
EDIT: RSR555 says "under left hand front wheel well under the passangers feet" currently websense is blocking his participation at work :(
2coupedup
Post by 2coupedup » Wed Sep 07, 2011 4:56 pm
the entire dash is out, so not behind the glove box... not in the footwell...
ok i'll rip out the front seats (using them anyways) and pull up the carpet n check under the front seats and rear footwell...
cheers... i'll post pics for future reference
2coupedup
Post by 2coupedup » Wed Sep 07, 2011 5:40 pm
... still no...
just checked out the harness and there doesnt seem to be any ECU type plugs...
any chance the computer is attatched to the engine harness???
Post by Alex » Wed Sep 07, 2011 5:58 pm
this thread shows it on the passenger side...
http://www.google.com.au/imgres?imgurl= ... m=1&itbs=1
this is where it must be!
2coupedup
Post by 2coupedup » Wed Sep 07, 2011 6:08 pm
i even ripped up the sound insulation stuff...
and as i said i have followed all wires that come through the fire wall and only unplugged what i couldnt unbolt n leave attached...
the engine is strange compared to any ej ive seen... ej202
there seems to be no shielded wires (like sensor wire sets to the ecu) in the bulk harness???
just resently wired up an ej22 ecu and all the sensor wires are sheilded throught the bulk harness and engine harness...
its a freak...
Jeff
Post by Jeff » Wed Sep 07, 2011 7:03 pm
If it is a 2000 model NA then the ecu is mounted on the drivers side head at the rear of the engine
2coupedup
Post by 2coupedup » Wed Sep 07, 2011 7:26 pm
aluminium mould with a plastic backing and just 2 square plugs???
if so your the man jeff...
looked suss... but just assumed it was part of the cruise control or emissions crap...
i gather this will mean less wires i have to deal with comming from the ecu into the body...
cheers
P.S. will add pics here for interested parties in the morning...
2coupedup
Post by 2coupedup » Thu Sep 08, 2011 11:35 am
a massive thanks to FROG and JEFF
Post by Alex » Thu Sep 08, 2011 11:49 am
awesome! wow, thats different!
taza
Post by taza » Thu Sep 08, 2011 2:51 pm
Wow, thanks now I know if I ever need to know for my Foz :mrgreen:
Isn't it a bad idea having it there though in case in gets wet?
GOD
Post by GOD » Thu Sep 08, 2011 6:09 pm
What's this then?
That's a 1999 Foz EJ20 harness, and it has that box on the back of the RH head, as well as this conventional ECU (?). I assumed the thing on the engine was just a junction box of sorts.
Dane.
2coupedup
Post by 2coupedup » Thu Sep 08, 2011 9:43 pm
where is that located?
FROG
Post by FROG » Thu Sep 08, 2011 10:09 pm
whats the number directly under 'S M' ? 1111 AA 111 ???
GOD
Post by GOD » Fri Sep 09, 2011 12:05 am
2coupedup wrote:where is that located?
In a cardboard box under the bench in my shed:p. Sorry, I didn't pull the car apart, so can't tell you much. It's within about a foot of the test mode connectors (green pair and black pair), which is in the vicinity of the ignition barrel.
Numbers on it are:
SM
31711 AE250
A64-000 D4Z
This gear came out of a car with an auto transmission, if that makes a difference.
Dane.
FROG
Post by FROG » Fri Sep 09, 2011 8:10 am
Yes it does matter thats the TCU
