Driving home yesterday check engine light came on and cruise light started flashing
pulled over checked vitals everything fine car still running sweet, got home performed on board OBII code check C0114 came up which is as ABS issue code i suspect from lifting wheels and removing abs fuse on fraser, cause was sick of abs suddering i think this code has been there for a while. more of a concern is the P0030 code which came up next, 02 sensor issue, which interesting conincides with a can of Liqui-moly injector cleaner .any suggestions on my next cause of diagnosis, can you clean o2 sensors ?
outback throwing codes
My friends Outback was doing this same code and shuttering. I put it on the scanner and found the LHF wheel bearing (this has the ABS sensor in it) was playing up. I replaced it and all was good for a couple of weeks, now it's back again and haven't had it back on the scanner yet.
Let me know if you solve it and I will do like wise.
