My faithful sportswagon started to make a strange rattle today. I turned the engine off, restarted and it went away.I drove about 7km stopping a couple of times, then just as I got home it started again. I opened the hood and I think the noise is the main fan rubbing against the plastic cover that is over the top of it? The shaft that comes out of the water pump that drives the fan is loose, and there is a lot of movement in it.and the fan can move around quite a bit. I noticed there is a bit of coolant coming out under that spot, not much though.
Thanks
RTF
