92' L Series Heater Blower
Posted: Thu Jan 05, 2012 12:30 pm
G'day all,
I'm having a hiccup with the blower motor in my 92 L Series wagon. After a hot day a couple of weeks ago, I restarted the car after a short break and popped the two 15amp "heater" fuses.
I inspected all the wiring and found two wires had shorted out under the clutch pedal, which I cut out and repaired. However after replacing the fuses, the blower does not work.
I tested the blower motor direct from the battery, it works fine, the brushes inside the motor still look okay too.
I also confirmed there is 12 volts going to the blower as soon as the ignition is switched on (even though the fan switch is off! - which also makes me wonder how it is earthed because both blades on the plug to the blower have 12 volts???). Huh?? I thought you could only have one positive and one earth? Or does the switch operate some relay that earths somewhere else? I'm confused!
If I switch the A/C on, the compressor engages when the fan switch is turned on (even though the blower doesn't start up), which makes me think the fan switch is still okay.
Any ideas? And just out of curiousity... why are there 2 x 15 amp fuses on separate circuits?
Dave
Dave
