where is fuel pump on an impreza 2000????
Posted: Wed Mar 14, 2012 2:03 pm
by GTFOZZY
Please help guys need to find the fuel pump on the 00gx impreza,have a work shop cd but it isnt compatiable with windows 7 grrrrrrrr!!!!!
Posted: Wed Mar 14, 2012 2:22 pm
by Alex
fuel tank....accessed under the rear passenger seat or in the boot.
Posted: Wed Mar 14, 2012 2:47 pm
by RSR 555
Yep.. in the fuel tank.. access behind back seat on drivers side under the oval shaped cover plate. Be careful pulling it out as it has the fuel sender unit attached also.
Posted: Thu Mar 15, 2012 9:27 pm
by GTFOZZY
Thanks guys does anyone know why no power would be getting to the fuel pump.car just died outta no where.no fuel was coming out so have changed pump still not working,i not sure what fuse is associated with the fuel pump.
Posted: Fri Mar 16, 2012 5:29 am
by Gannon
The fuel pump is powered by the fuel pump relay, which is located right beside the main ignition relay and has a green 4 pin plug.
The fuse for the fuel pump is rather large and supplies the entire fuel injection system, so I doubt it would be that. Is it possible that when you were playing with the main ignition relay a little while ago that something has come loose?
Does the fuel pump run for a couple of seconds when the ignition is first turned to on?
When you turn the ignition on, does the check engine light come on?
When you connect the 2 green 'check engine' plugs together, do the radiator fans cycle on and off?
The fuel pump relay plug has 4 wires, one fat one is constant supply from the fuse in the engine bay fuse box and will be the same colour as 2 of the fat wires at your main ignition relay. The other fat wire goes to the fuel pump. One of the thin wires is supplied by ignition power from the drivers side footwell fuse number 16. The other thin wire is grounded by the ECU.
Posted: Fri Mar 16, 2012 1:23 pm
by RSR 555
Check the usual stuff like fuses and relay but don't forget immobilizers
Posted: Fri Mar 16, 2012 6:25 pm
by alang
GTFOZZY wrote:Please help guys need to find the fuel pump on the 00gx impreza,have a work shop cd but it isnt compatiable with windows 7 grrrrrrrr!!!!!
try this for manual
http://jdmfsm.info/Auto/Japan/Subaru/Impreza/2000/
some times you can right click on the file if windows is see it and change the compatibly to show older version of windows files
Posted: Fri Mar 16, 2012 6:35 pm
by alang
