Error codes SF Forester
Point
Post by Point » Sun Apr 22, 2012 1:24 pm
Does any one know where I can find the list of codes or a manual for the early SF Forester? I have a check engine light and a code 54.
I have looked at various threads, and online workshop manuals, but it seems that the Aussie SF is a bit different to everything else.
The car has been sitting for a while and now that I've got it running it has a rough idle and the check engine light stays on. It is also currently unregistered, so I can't take it anywhere, and I won't be able to register it with this code...
98 Forester GX
02 Forester XS Luxury
Post by TOONGA » Sun Apr 22, 2012 2:06 pm
http://jdmfsm.info/Auto/Japan/Subaru/Forester/
the link above is probably your best bet
Point
Post by Point » Mon Apr 23, 2012 12:04 pm
Thanks Toonga.
after going through that site, and pdftown as well, and downloading a few hundred meg of various manuals (I tried some other models too) I still can't find the right one. These manuals show MAFs, cam angle sensors, ECUs under the dash, and they look to be OBDII. Mine has a MAP sensor, crank angle sensor only, and the ECU is bolted to the drivers side head.
The closest I could find (with a listing for 54, most don't go past 53) was under 'Subaru specifc troule codes' found on scoobypedia. It listed 54 as 'air intake system', which doesn't narrow it down much.
I tried the air temp sensor to no avail, MAP sensor is next. Will see how that goes.
98 Forester GX
FROG
Post by FROG » Mon Apr 23, 2012 2:45 pm
workshop manual says : because the ducts and hoses on intake line are loosened or damaged, the pressure sensor signal is abnormal"
Point
Post by Point » Mon Apr 23, 2012 6:26 pm
thanks for that Frog.
I tried another MAP sensor, no change. I didn't have all of the airbox ducting installed, so I tried that, but still no change. I will have to have a closer look and see if there are any cracked vacuum lines when the light is a bit better, but I couldn't see any before.
98 Forester GX
Post by NachaLuva » Thu May 03, 2012 12:19 am
I use Subaru Engine Codes - troublecodes.net ...it says "Choke control system".
Not sure if that helps though...
Point
Post by Point » Thu May 03, 2012 8:15 pm
Unfortunately that is under '83 - 88 Subaru carb models'
Why a carb engine has an ECU is beyond me.....
98 Forester GX
Post by NachaLuva » Thu May 03, 2012 9:58 pm
Point wrote:Unfortunately that is under '83 - 88 Subaru carb models'
Good pick...my bad! :rolleyes:
Yeah, bit weird hey :confused:
Post by RSR 555 » Thu May 10, 2012 1:22 am
Where and how are you getting these codes?
Does you engine have the black plastic manifold?
When the engine is running, can you spray some CRC (or similar) around the manifold area and see if the revs change?
