Is it simply a bolt off / bolt on job, or is their something special I need to do? Looks like a 17mm and 19mm socket job, but the bolt nuts seem to be pretty tight. Can I use a rattle gun to undo the nuts, or should I stick with a socket set and some more muscle?
I was thinking of removing the front sway bar at the same time as I replace the con rod. The rod has bent where the sway bar connects to it.
Probably sounds like a pretty lame question to some of you guys who have done engine transplants, but as I said I've never done it before so I thought I'd ask for some advice first.
