Turns over, splutters, won't start.
Posted: Sun Sep 16, 2012 6:45 pm
Hi, it's been a while since i've posted on here but i'm stuck for what to do with my problem.
I have a Subaru liberty RX 2000 model, manual. Since about a month or two ago the car was have a rough idle on startup. It would start fairly easily, without much hesitation and the first few seconds would have a very rough idle. Over time this got worse, where the car would not start start up, and took two goes to start, as well as the 10-20 seconds of rough idling (sounding like lawnmower) then it would seem fine.
On the last tank of fuel I ran some injector cleaner through the car, and drove 4 hours no worries, then a short trips of 5-15 minutes. Finally the the next day I went to get in the car and it wouldnt start at all.
The car turns over fine but ill it does is splutter a couple of times while the key is turned then stops spluttering shortly after you stop turning it over. It doesn't actually start at all.
After trying to figure it out I called a mobile mechanic to come take a look. THe guy took a look over it and checked in intake, checked one of the spark plugs, did a pressure test and checked fuel was being pumped in.
My thoughts initially were fuel pump or filter, but it seems to be getting fuel to the front when we took off a fuel line in the engine bay. I have one of the models with the fuel filter and pump located in the actual tank.
We found that the coil pack had one very corroded contact, which we had a go at scraping off some corrosion but this didn't help at all.
The mechanic guy was fairly short on concrete ideas. He said that it could be a number of things including the coil pack needing replacing (he suggested this as one terminal was already corroded). He also suggested changing the plugs and wires too. Another suggestion was the camshaft sensor? However there has been no check engine light and no codes were revealed when he checked.
So my question is does anyone have any experience with a similar issue?
I find it strange that the car would slowly have this sort of problem that would become gradually worse, then to not work at all. I want to have the best possible idea before I start throwing too much money at the car.
Regards and much appreciation,
Jack
Jack
