Gen 2 lib: intermittent electrical/ignition problem
Posted: Wed Jan 30, 2013 5:33 pm
I have an intermittent problem with my Gen 2 Lib that I am having trouble tracking down.
I initially thought it was the fuel pump, but suspect it isn't as I thought it would just let go and not drop off for only a second at a time. Happy to stand corrected on this though.
So I think it must be in the electrical/ignition system somewhere, cuts out for about a second at a time. If it happens when coming up a driveway, ie low revs/changing down, the thing stalls and I get reds on the dash. If it happens at speed, the electrics keep running (ie dash backlighting on, no reds on dahs), and it eventually starts up again as the engine is still turning over. It's just like taking the foot of the accelerator and then putting it back on again a second later. Sometimes it won't happen in a day, sometimes 4-5 times.
I have tried the following things:
* Replaced the fuel filter.
* Replaced the ignition relay with the 2xBosch relay mod listed here on the forum.
* Checked the fuel pump relay. (Swapped the relay with the blower relay below it, but still happening. At least now that I know they are the same, a good thing to keep in the back of the mind in case I am ever stuck out on the road.)
* Ran the engine and fiddled with the wires/terminals in the engine bay to see if I could reproduce the problem. Was a suggestion in another thread here a little while back.
* Checked the fuel pump connections but everything appeared solid, and no visual contamination/degradation of terminals.
* Also replaced the knock, cam position and coolant temp sensors (long standing error codes).
Any ideas/suggestions gratefully welcomed.
Cheers, AJ.
Cheers, AJ.
