brumby weber surging up hills
- brockharro
hey
ive got a brumby with a weber on it all ran well then started to surge up hills and more when i put the foot down and sounds like its backfiring or exhuast gas pushing the aircleaner off
any sudgestions of what the problem could be would be awsome
cheers
brock
cheers
brock
- brockharro
- brockharro
I had bad fuel starvation with my brumby when I put a second hand Cortina webber and found after much swearing, found out that some wombat blanked the fuel supply off for the webber and used the fuel return line as the inlet. After studying the top a mate noticed the problem. The return has a small drilling to keep some fuel pressure on the needle and seat. Changed the blank off and carby worked fine, no fuel starvation anymore. My Brumby has a fuel return at the filter so I didn't use the webber return. Jetting is standard Ford
