L series ea82t surging
As the title says, i've got an ea82t (3 pin) from a RX in a L wagon and when driving along a flat road (not accelerating up an incline and not rolling down a decline) the car 'surges'. It feels like its getting held back then suddenly releases and surges forward (any continues doing this til I get annoyed and accelerate). If I accelerate it stops happening for a few moments.
I've been targeting the ignition as it is also misfiring at low revs (but not idle) when cold or for about 30-60 secs after startup. I've replaced the spark plugs (2 weeks ago) (is it a problem running a resistor type instead of a non-resistor type?), coil-dissy lead (today), coil (GT40 yesterday), and the dissy and rotor 'look good'. '
The spark plug leads had resistances from 5kohms (short) to 16kohms (long).
The coil to dissy lead originally on there was 9kohms but i replaced that with a new bosch one with only 2kohms. Can someone tell me what that all means?! - I assume that a lower resistance is better but are the numbers for the spark plug leads too high????
I started getting a ECS light intermittently today after I changed the coil-dissy lead, but only at relatively low cruising revs - I'm not sure if the 2 are related. It came up as code 12 (starter switch remains off). Changing the leads back over didnt seem to stop it happening.
My search for the cause of the code 12 led me to a thread with a vortex that had a bung fuel pump. I can clearly hear my pump running after I crank the engine then let the key go without it starting. It doesn't start any easier after a 'false start'.
But I wondered what the chances are that the surging problem could be a bad pump, a dirty/blocked fuel filter, or dirty injectors?
Has anyone suffered the same problems and discovered a solution???
The R stands for Resistor and is designed for points type dizzys that have a resistor (ballast) on the side of the coil. Electronic dizzys do not require the resistor.
I would say the surging is coming from a fuel issue. I would get the pressure output checked and also check the fuel regulator is working correctly
fpr is in the fuel rail in the middle I think, a cannister with vac line at one end.
I used a new Bosch coil lasted a year, went original from Japan as surging thing started up again on the Bosch. Coils differ between 3 plug and four plug ECU, no igniter with 3 pluggers coil.
Three pluggers coil part # 22433AA041 , was just over 100 bucks or so !
Yeah fuel pumps over the years on T and no T were different - blue label, green label and yellow from memory and they have a little damper built in on end. look the same though....
Yepajames wrote:Are FPRs and fuel pumps specific to the model? i.e. different for EA82T and EA82??..
The EA82 EFI FPR is in the fuel line return line on the manifold (sorry no picture on hand) but these ones were good (and I use that term loosely) but over the years they turn to sh*t and I would recommend you fit an aftermarket one like this one...ajames wrote:And what does the fpr look like? Has someone got a pic from an ea82t?
http://www.ebay.com.au/itm/ROADSTAR-EFI ... 416e456463
I'd also recommend you fit a new fuel pump. I'd recommend this one...
http://www.ebay.com.au/itm/New-Genuine- ... 232a9b85f6
RSR 555 wrote:Yep
The FPR is a good SARD copy, top stuff.
The walbro pump is a great option and a HUGE amount
quieter pump.
have you checked air filter as well?
I found that the fuel pressure regulator from N13 pulsar is the same shape and pressure as the EA82T one, and was only about $40.
I changed a heap of things trying to chase what felt like way too rich under boost, but the EGO gauge was reading lean, but not consistantly. I borrowed an adjustable FPR and reduced the pressure and found that it improved, but I was far from happy with it so I got the Nissan FPR as a replacement.
It ended up being the injectors. When I got them back from the cleaners, the guy said that they were spraying a stream of fuel, not a mist, no wonder the car was running crap and giving false readings on the EGO sensor
When you get the injectors serviced, make sure you get the little rubber hoses replaced as well.
I dont think so. They just had a sorta cone shaped ring at the injector end.steptoe wrote:Did you end up with clamps at injector nd Gannon..
edit:
Google image search
Yeah one of them came off while I was playing with the fuel rail one day. I just pushed the hose back on and slipped the collar on. The fuel rail above holds the injector hoses in place
+1 for replacing short hoses on injectors.
Recently had EA82 turbo injectors serviced off car. Got test measurment results all ok. Specified new hose pieces and basket filters and was told that the factory collar/clamp is re-usable. so was given hoses cut to length and old hoses removed from injectors.
Reused old barb/collars no worries.
Stuff using hose clamps.
