I killed my suby
I killed my suby
HI! i,m new to this,so be nice,i recently changed cam belt on 2003 impreza single cam [ej201?] ,runs good until warmed up then starts to miss intermittently and dies ,did basic service,plugs,oil/air filter ,did not touch electronics ,compressions are good,check engine light does not come on but am getting fault codes 13,31,33,23,24,should i buy a cheap scanner OR BURN THE IMPREZA AND KEEP THE BRUMBY,THANKS!
23 Air flow sensor Abnormal voltage input entered from air flow sensor Controls the amount of fuel (injected) in relation to engine speed and throttle sensor position X X
24 Air control valve Air control valve inoperative (Abnormal signal produced in monitor circuit) Prevents abnormal engine speed using "fuel cut" in relation to engine speed, vehicle speed, and throttle sensor position X X
31 Throttle sensor Abnormal voltage input entered from throttle sensor Sets throttle sensor's voltage output to a fixed value X X
32 Oxygen sensor Oxygen sensor inoperative none X X
33 Vehicle speed sensor Abnormal voltage input entered from vehicle speed sensor Sets vehicle speed signal to a fixed value X X
Try resetting the ECU and see if the codes return. See here : Fault codes and resetting ECU
If it starts and runs OK when its cold it is not anything major
No it just cleans the injectors.cordeck wrote:could injector cleaner have caused some damage?
Still suspicious bout what work you've done on it...timing belts, what else?
If the car ran fine until you changed the cam belt, it must be something that was altered/unplugged during that process. It would be a huge coincidence (although not impossible) if another part just happened to fail at the same time. Can you think of anything that you may have disconnected or re-arranged during the cam belt job?
