Need details of under Brumby bonnet
Posted: Wed Jan 01, 2014 12:51 pm
This should get all Brumby readers in for a start.Thanks. It is the black plastic pollution thing that is about size of a nice ,juicy jam donut, connects somewhere near LHS of air filter box.
It is part of a plastic pipe section with air baffles ? in it.
Anyone able to describe where both ends of the assembly fits in ?
There is an alloy valve thingy in the equation also, bolts to oil filler neck...just a little lost as to what goes where.
It is all part of the EGR alternative system you have when you no longer have that cast iron EGR valve unit with vacuum diafragem on it.
Looks like it and all its little bits add fresh air to exhaust off the LHS exhaust port, feeds through various chambers and finally direct to the piped plate bolted to EGR spot on inlet manifold.
Lost everyone ?
Lost everyone ?
