Coolant flush?
Nobby
Coolant flush?
Post by Nobby » Fri May 02, 2014 8:26 am
Hi all, I have a 1991 Liberty 2.2 and I have just redone the head gaskets.My question is what do you think about flushing out the cooling system?The car was running just water when we brought it and I am thinking it would be good to give it a good clean out before I put fresh coolant in.
Has anyone had a good result with a chemical coolant flush,or is that a bad idea?
I have already flushed the system 2-3 times with just water and it is running clean at the moment, but I would like to know that all the rust and junk is out of it just to be sure.
Cheers Robby.
Post by steptoe » Fri May 02, 2014 12:01 pm
I have had good results with Nulons cleaner, cleaned things a little bit too good, but, I guess it was gonna happen one day at a worse convenient moment ! Used it a few times on other cars non turbo and their turbos did not spring internal leak, just cleaned a lot of gunk internally
Post by RSR 555 » Tue May 06, 2014 11:00 am
I also recommend the Nulon Radiator Flush but really recommend buying a new radiator off ebay and fit that after you have done the flush.
Nobby
Post by Nobby » Tue May 06, 2014 8:40 pm
Thanks for the replies,but why would you replace the radiator after the flush RSR 555?
