A/C Idler pulley seized
henpecked
Post by henpecked » Tue May 26, 2015 8:30 pm
Ive just had an idler pulley seize ( smell that belt !! Hmm Hmmm ) I suppose I have 3 options
1) get one from a wreck or from my spares ( will be 30 years old)
2) buy a whole new pulley from Subaru ( my first "new" part - if available)
3) Press in a new bearing
I would prefer to do ( get done) 3 , as I then get a new bearing
anyone have any hints/ tips or suggestions please.
Brumby_ProjectX
Post by Brumby_ProjectX » Tue May 26, 2015 9:32 pm
New bearing and press it in. I think mine was about 16.00 from cbc. I had to clean the pully up on the lathe a bit though the heat from seizing it distorted it a little and it had a bit of runout in it. The hardest part is getting the circlip out so 15 minute job tops.
Cliff R
Post by Cliff R » Tue May 26, 2015 10:54 pm
Yep, get the old bearing out, get a new one and press it in.
By far the easiest and best result.
Nubaru
Post by Nubaru » Wed May 27, 2015 8:04 am
done the new bearing thing a few times in these idlers, say a few times then gave up for could not get the thing to sit in perfectly square and idler wobbled once in place. Went for a good used and never looked back
Brumby_ProjectX
Post by Brumby_ProjectX » Wed May 27, 2015 9:37 am
Nubaru wrote:done the new bearing thing a few times in these idlers, say a few times then gave up for could not get the thing to sit in perfectly square and idler wobbled once in place. Went for a good used and never looked back
If you have access to a lathe it pays to give it a quick skim. I took off about 0.2 max from memory
Subydoug
Post by Subydoug » Wed May 27, 2015 11:59 am
Freeze the bearing and heat the housing. It will drop right in without a press.
Doug
Cliff R
Post by Cliff R » Wed May 27, 2015 8:22 pm
I have used a socket to press the bearing in and used a vice as a press.
Then I bought a press.
WagonJunkie
Post by WagonJunkie » Thu May 28, 2015 5:49 pm
I had the same issue (although mine wasn't completely seized)
I bought a bearing from a bearing shop (duh?) and then paid a workshop $10 to borrow their press. It went right in , no worries. I fitted a new belt at the same time.
20,000 kms later it's still good....but I have had to re-tension the belt a number of times to eliminate squeeling.
henpecked
Post by henpecked » Thu May 28, 2015 6:15 pm
thanks people, all ixed with a new bearing inserted last night ( from cbc on south road), used a "freeze bearing) and " BBQ heat pulley" method with a socket and hammer.
cheers
