3 Inch lift - No reverse!
Tim82
Post by Tim82 » Fri Jul 07, 2006 2:59 pm
just swapped my 3 inch lift over from my 82 wagon into my 91 brumby and have found out i cant get it into reverse now and second is slightly hard to get into also.
any ideas on what it could be and how to fix it?
Cheers Tim
MUDRAT
Post by MUDRAT » Fri Jul 07, 2006 5:51 pm
If you can remove the gearstick, bend it forwards and to the left just slightly.
SuBaRiNo
Post by SuBaRiNo » Fri Jul 07, 2006 10:51 pm
Where did your lift kit come from???
Are your gear box blocks an inch smaller than the rest of the kit?? or are all the blocks the same height?? Does the 4wd leaver also sit up rather high??
Dave
Dougz
Post by Dougz » Sat Jul 08, 2006 1:37 pm
I had the same problem in my 89 brumby with 3inch lift. I removed the gear lever and cut the kink out to move the main shaft to the left (but kept the same angle) as it hits on the 4wd selector bar. Basically means it is now straight but I should have moved it slightly to the left as it still hits but it works. Removing the kink has shortened the lever a bit but It seems better a bit shorter.
Sorry didnt get a before pic..
Dougz....
84 Brumby - (Project rally car, one day)
89 Brumby
86 Touring Wagon - (with aftermarket turbo)
2004 BA Falcon Ute
2005 VZ SV6 Commodore.
Subaman
Post by Subaman » Sat Jul 08, 2006 5:17 pm
Just replace the bushes in your linkages and all should be fine.
SuBaRiNo
Post by SuBaRiNo » Sat Jul 08, 2006 7:35 pm
Thats a point... could be the link between the box and the selector.
Look at this site..
http://www.usmb.net/repair/?CurrentDire ... 938007.art
Dave
aspro
Post by aspro » Sat Jul 08, 2006 8:46 pm
What box are you running in your brumby. HJad a similar prob when I did the box on my lseries. It runs a ej dual range box. Turns out it was just the pivot bot in the wrong way around,
Tim82
Post by Tim82 » Sun Jul 09, 2006 2:44 pm
Thanks for the input so far guys :wink:
the lift kit is a BYB 3 inch with the usual 2 inchblocks for gearbox
gearbox is just the standard dual range 4 speed, just want a quick fix for it as i have a trip planned for this coming thursday. going to convert to a five speed after this trip.
i might try the shifter slop stopping from dave and see if this helps, hopefully it does.
ill let you know how it goes.
Cheers Tim
Tim82
Post by Tim82 » Tue Jul 11, 2006 8:36 pm
Hi Guys
all good now thanks to fixing the shifter slop.
thanks dave for the link to the other info :wink:
Cheers Tim
SuBaRiNo
Post by SuBaRiNo » Tue Jul 11, 2006 9:02 pm
No worries mate... I found that to be a great link too... made me wish we had something similar on this site.
It's an extreamily common problem... i learnt the hard way many many years ago... replaced the gear box before i realised it was just the linkages.
Dave
