update,
Talked to dave - jack sparrow - last night about the circlips, and the flatblade screwdriver trick. Tried it out this morning and it worked! it was a bit of a mix between using a right angle pick and a thin flat blade screwdriver then a bit of levering :P
After that there was another circlip i had to pull out around the rear of the mainshaft, but by then the end plate was off and out of the way!
Then after more jiggling around i discovered that i had to pull of 2 of the selector rods - the main gear rod, and another one connecting to the centre diff (more about that in a moment)
After i got all the bolts, the circlips and those 2 selector rods out, the box basically fell apart
The main reason i was pulling apart is because the person i got it off claimed that the input shaft bearing was starting to get noisy... Looked at the input shaft bearing and it seems like its fine! no pitting/scoring in the bearing track, or on the needle rollers! It seems to make a little bit of noise - after checking it out with a stethoscope compared to the other input shaft bearing! So it seems like there is nothing wrong with it. But then again i dont have much experience with bearing wear... So can a bearing 'look' alright, and 'feel' alright, but once its under the load and speed of the engine, that it becomes noisy?
And the other thing i was going to mention is that the gearbox seems to have a locking centre diff! It is a mechanical open diff (as opposed to a viscous coupling), and it has a shifter to lock the diff housing to the mainshaft making it locked centre! However i dont have any linkages to set this up - however if i were to go offroad, i'd just have to crawl under, shift hte linkage from the external lever, and off i go in locked centre 4wd
Very happy with my finding hehe.
Anyway, if anyone can let me know how to properly diagnose an input shaft bearing (from in my hand, not from in the car) that would be great!
-Adam
