86 leone running strangely
Posted: Tue Sep 19, 2006 3:29 pm
by midlifecrisis
Hi people
I have a 86 EA82 leone that is doing some strange things like the tacho is jumping around ,when the revs are low all the warning lights start to glow and it seems to have a miss and it sounds like it is pinging for a short time 15-20secs then runs good again,it only does the miss and pinging sound every so often not all the time.:confused:
Does anyone have any ideas as to whats may be going on ??:confused:
thanks for any help
Marc
Posted: Tue Sep 19, 2006 3:34 pm
by D3V1L
when ur warning lights etc are comming on at low revs it sounds like your alternator is not producing power...probably as a result of the low revs
Posted: Tue Sep 19, 2006 4:01 pm
by midlifecrisis
Hi thanks
It is not only the Alt light that comes on it is all of them eccept the oil light.
Marc
Posted: Tue Sep 19, 2006 4:08 pm
by D3V1L
yeh....from experience thats what happens....all the lite come on and are sort of dim....im not to sure whats causing the low idling and pinging though..somebody else might be more in the know than me...
Posted: Tue Sep 19, 2006 4:31 pm
by midlifecrisis
Oh ok thanks I new to the subie thing, so do you think I should get the alt looked at.?
Marc
Posted: Tue Sep 19, 2006 4:42 pm
by D3V1L
mmmm....wait for a few other guys to offer their opinion first....somebody might know something....
Posted: Tue Sep 19, 2006 5:45 pm
by chubby37
sounds like alternator to me or crossed or cut wire touching on metal....do you have trouble starting it?
Posted: Tue Sep 19, 2006 6:08 pm
by MUDRAT
What's the voltage?
Posted: Tue Sep 19, 2006 6:58 pm
by midlifecrisis
Ok no trouble starting starts great first turn of the key.
The cut or crossed wire where would I look for this at the alternator?
Thanks
Marc
Posted: Tue Sep 19, 2006 7:11 pm
by SubaRute
find someone with a multi meter and get them to check if the alt is charging the battery,off memory i think your battery should be charging around 13 to 14 volts/amps ,people who use multi meters should know what to look for.good luck
Posted: Tue Sep 19, 2006 7:25 pm
by midlifecrisis
ok I have a mate who has one so will get him to check it out.
thanks
Marc
Posted: Tue Sep 19, 2006 10:48 pm
by Suby Wan Kenobi
Sounds like i am gunna agree with all the others here and say its your alternator. This can also cause the pinging that you have as if there is insufficient power to make the car run eradically this will also tell the fuel cut off on the carb to shut off as well as producing a less then great spark.
Posted: Tue Sep 19, 2006 11:37 pm
Had just same in the Brumby. Swapping over alternator fixed it. Only an at idle problem and 'overlooked' it for weeks and weeks. never let me down.
My L without an engine , did it before engine came out so lookin' forward to same fix
and for once I do not agree with Suby Wan in the 'as well as producing a less than great spark' - if your problem is only at idle
14.4 to 14.8 volts is what your look for on a multimeter at medium revs
if multimeter battery inside itself is weak I have had higher readings , like 17 volts ! aka false reading
Posted: Wed Sep 20, 2006 6:36 pm
by midlifecrisis
Hi guys
Great for the info I will go tomorrow and get another alternator and will let you know how it goes.
I checked the dissy today and found the plate was sticking so freed it up so I will see how the pinging goes now.
thanks again
Marc
Posted: Wed Sep 20, 2006 10:15 pm
by soobs_rule_m8
13 to 14 volts from your alternator is normal. See if the voltage drops when the problems occur. That will signify there is a short in your wiring somewhere. If it does, it will probably be between your battery and starter motor positive wire. If it was a shorting problem anywhere else the fuse should blow for that circuit. You could also try disconnecting the charging wire (biggest one) from your alternator once your engine is running. That way you ignition/spark plugs are running purely off your battery. If the fault goes away, you may have a dodgy alternator. Don't leave it like this for too long obviously as your battery will go flat. Good luck
Posted: Thu Sep 21, 2006 5:00 am
by midlifecrisis
Thanks Soobs I wll do what you said this arvo and see what happens, I would rather change a wire than a alternator
Thanks
marc
Posted: Thu Sep 21, 2006 2:38 pm
by midlifecrisis
Hi
After driving the car for 2 days since I oiled up the dissy it seems to have stopped the ping/miss stuff, Just have to work on the alternator.
Marc
Posted: Tue Sep 26, 2006 10:50 pm
by midlifecrisis
Ok I got another alternator today so will put in tomorrow and see what happens.
Marc
Posted: Thu Sep 28, 2006 12:59 pm
by midlifecrisis
Ok I put the new alternator in yesterday, Went for a drive last night and no warning lights so far, So it's looking good.
So thankyou to everyone for thier ideas and info.
Marc
