Leaky windscreen
Leaky windscreen
My L-series has started to leak from the right hand corner of the front windscreen. There is a touch of rust coming through at the top edge of the windscreen in the middle which is probably causing this. Is it likely to be anything else? Like the seal just not working anymore?
Has anyone removed the windscreen, fixed the rust, and managed to seal everything up properly again? If so could you please give me a quick how to?
- johnarentz
Re: Leaky windscreen
Hi,LTurbo wrote:My L-series has started to leak from the right hand corner of the front windscreen. There is a touch of rust coming through at the top edge of the windscreen in the middle which is probably causing this. Is it likely to be anything else? Like the seal just not working anymore?
You could try Fyshwick Panel and Paint, they seem willing to provide a range of services to suit the pocket. If it is the seal then one of the wiundscreen fitters would be the way to go, probably new screen and fitting kit.
I noticed that this is also happening on the bargain L I picked up yesterday...so far the bargain has been diagnosed with stuffed compression rings on one cylinder, dud water pump and now the bastard leaks.....oh well you can't win every time.
Rust in a subie ? Never !!
The best repair I have seen for rust holes the size that appear in the corners of these is fibreglass and resin once rust cut or cleaned out.
Mobile windscreen guys are good value when you want screen removed one time, give you time to repair and then get 'em back to finish off for you.
Bonded windscreens aren't they ? suba ?
I had this fixed in my L.
You need to take it to a panel beater. They will take the glass off and most likely, the metal behid the glass is all rusted. Happens to every Leone.
If you are lucky, and the rust did not go through the metal, then the panel beater would need to sand the rust, spray it with rust converter, cover it with primer putty (make sure its the green zinc based stuff), and respray.
This whole job cost me around $300 in Melbourne around 2 years ago. If your glass breaks, that will be extra obviously.
Finally, make sure when the glass goes back in, the glass man uses plenty of silicon, but does not cover the little drain holes.
Sorry, I did mean urethaneSuba wrote:Please dont use that word Silicon around any decent windscreen fitter as we hate the stuff.
Yes the LSeries are bonded in with Uerethane, once it sets it is very much like rubber and it isn't acetic like most silicon's are.
Mike.
I removed a windscreen from an L series the other day. It took a while because I had to cut through all the sealant that holds it in place. This car was in very good condition, except for the smashed front end, but there were signs of rust under the windscreen. I think that they may be prone to rust in this area that makes them leak, just like my L series.
Suba,
Are there any pitfalls to lookout for when fitting the new screen. I was going to just clean up any rust then put a large bead of sealant around where it was before, then put the windscreen back in place. If it's not as easy as that please let me know.
Suba,
so dodgey 8Otreat the rust holes with cold galv then fill them with windscreen sealant.
that will never work for long, if the rim is rusted,with holes, the only way is cut and reweld steel there (preferably galvanised steel), elsewhere around the windscreen fibreglass&resin works really well and recommended.
I also 2nd the recommend of using mobile windscreen fitters, take the windscreen out yourself (or they can come and take it out and quote the new one) fix the rust yourself, don't trust panel beaters unless you can check up on their work.
I checked every stage of panel beaters work - ie sanding/treating, puttying, and respraying. They might get annoyed, but cant do much about itfred-sub wrote:so dodgey 8Otreat the rust holes with cold galv then fill them with windscreen sealant.
